| Help.Anybody know the procedure for storing and calling subs in your main program instead of outside of it? For example Mazak uses (M98 H ) to call a sub stored within program and an N# to describe it. M98H1000 . . . . . . N1000(SUB) Thanks in advance
__________________ DB34 |
| I have not done that in MANY years, but if memory serves me it works something like M99 (either N or P) then the line number M99N1422 or M99P1422 This is not going to be a conditional jump (with IF-THEN) nor are you going to be able to use M99 as a typical "return". Like I said, it has been a very long time since doing that so I would suggest opening up that FANUC programming manual and look at the descriptions for both M98 and M99. Sorry, that's all I got. Chris |
| Fanuc doesn't really have an internal sub routine ability like Mazatrol, Haas, Yasnac, etc. You can use the "M99 P... " like Chris mentioned but it has some drawbacks. It will act like a GOTO statement and not really a sub. And I'm not sure if the 15M can use the code like that so you'll have to try it and see. Other options are to use things like While/Do loops and such.
__________________ It's just a part..... cutter still goes round and round.... |
| I know on the niigata with 15 you can call a sub program as a macro. Then after it's do it will return to the next line after the call. G65P8012 but m98 jumps to a sub or macro m99 jumps out of a sub or macro but then i know that m99 also can be repeat program so ... I'll double check when i get to work tomarrow and repost |
| Why not just call separate programs with M98Pxxxx. Each sub can return to the main program with an M99, and you can also nest subroutines by making M98 calls within subs. The only downside to keeping your subs separate is is that you have to upload and download multiple programs to the CNC for each job (one main plus many subs). On the 15M, though, this is easy to overcome. Here's how you can do it: Keep your program numbers together for each job. If you use, say, O1234 for the main program, and keep your subs called by that main program in sequence, like O1235, O1236, O1237, etc. You can then put the main program and all the subs in one FILE on your DNC system, like so: % O1234 (MAIN) N1 N2 (etc) M30 O1235 (SUB1) N1 N2 (etc.) M99 O1236 (SUB2) N1 N2 (etc.) M99 O1237 (SUB3) N1 N2 (etc.) M99 % (be sure that there are only percent signs at the begining and end, and NOT in between the programs. Then, when you download to the CNC, just queue up the file on your DNC system and press READ then ALL to download all the files together. When sending them back to your DNC system, press PUNCH then PROG#, then key in "1234", then press PROG# again and press the number of the last sub (1237) then press EXEC. That will send all the files within that RANGE to the DNC system for storage in one file. Just make sure your DNC system will not break down the data into 4 separate files by O-numbers. If your DNC system receives until a timeout occurs, you'll have no problem with uploads. Keeping your subs separate from the main has several advantages. You can call each sub multiple times, or you can call subs from other subs (nesting up to 5 layers deep). |
DITTO Keep it simple, The biggest mistake I see a programer or an engineer (Such as myself) make is thinking just way to much. Just let go your mind and use the "FORCE" It always works for me Bluesman |
#10
| Thanks all but I need to loop these subs many times per program and although WHILE DO loops will work they are somewhat wordy for what I am trying to accomplish. Also, I like to keep these subs local because most are part specific. Any part families w/common features will have macros instead. Here is an example of 2 simple routines that need to be called repeatedly .It is for a 2.913 x .85 slot N80(.75 PLUNGE MILL) G65P6000T28A27 G0G90G56X-5.375Y0.Z5.M3S2900M39M51 Z1. G98G81R.1Z-2.1F26. M98 H1000 L13 (incremental plunge sub 13 x's) / N90(.75 HI POS) G65P6000T27A27 G0G90G56X-5.5Y0.Z5.M3S3000M39M50 Z1. G1Z0.Y.05F50.G41D27 M98 H3000 L15(slot finish sub 15 x's) G90G3Y0R.025F30. G0Z5.G40 . . . . . .M99 .N1000(PLUNGE SUB) G91 X.125 M99 N3000(FINISH SUB) G91 G3Y-.1R.05Z-.063F20. G1X2.063Z-.063F40. G3Y.1R.05Z-.063F20. G1X-2.063Z-.063F40. M99 % As you can see this saves much cutting an pasting of code While I realize these could be changed into macros, time is often not permitting and the quick and dirty way is needed. Please let me know if what I'm doing can be done a better way. As for storing subs in sequencial order; our numbering system won't allow this
__________________ DB34 Last edited by BROCD; 02-22-2006 at 09:04 AM. |
#11
| Well other than breaking your subs out to seperate programs like Dan mentioned I don't see an easy way to do what you want on a Fanuc control. And really the only differance between that and what you just posted is how many programs show up on the control (just change the N1000 and N3000 to O100 and O3000). You can keep them together as a single file on the computer. If you only have 1 part program loaded to the control at a time you don't have to worry about program numbers interfearing. Just remove all programs before loading a new part. If that isn't good enough I suggest spending the time to make the macros for what you do most. Dale |
#12
| Try this. I can't prove it right now but it should do the trick for you. N80(.75 PLUNGE MILL) G65P6000T28A27 G0G90G56X-5.375Y0.Z5.M3S2900M39M51 Z1. G98G81R.1Z-2.1F26. M99P1000 (incremental plunge sub 13 x's) N1001 / N90(.75 HI POS) G65P6000T27A27 G0G90G56X-5.5Y0.Z5.M3S3000M39M50 Z1. G1Z0.Y.05F50.G41D27 M99P3000 (slot finish sub 15 x's) N3001 G90G3Y0R.025F30. G0Z5.G40 . . . . . .M99 .N1000(PLUNGE SUB) #100=0 WHILE[#100LE13]DO1 G91 X.125 #100=#100+1 END1 M99P1001 N3000(FINISH SUB) #101=0 WHILE[#101LE15]DO1 G91 G3Y-.1R.05Z-.063F20. G1X2.063Z-.063F40. G3Y.1R.05Z-.063F20. G1X-2.063Z-.063F40. #101=#101+1 END1 M99P3001 % |
