Old 09-16-2003, 09:51 PM
9566317 is on a distinguished road
Post Wasino with Fanuc OM controler
We upload and download programes all the time with text in the programes.We will identify tool type and dimensions to be achieved.Seems to simplify setups.
Problem is this machine wil not show it.When transfer is done in either direction text is gone.
Is this an option that I need to buy and if it is what do you call it?
Is it just a bit that needs to be changed or am I needing boards and etc>>
Any thoughts out there.It is an old machine mid 1980's
Old 09-17-2003, 12:31 AM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
Number man,
Do you put your coments in ( ) ? Also some,(I did say some guys) Fanucs require the coments to be all caps.
Also what model OM (a, b or c)?
Old 09-17-2003, 07:58 AM
Wink
Yes we put text in ().Controler does not have () keys but we do not programe at machine.
It is a model C controller.
I will try the caps though,never thought of that.
Old 09-17-2003, 06:22 PM
Thanks for the start WMS.
Yes we have tried () with caps only.This is how we normaly do it.
Tried with square brackets still no go.
Old 09-22-2003, 12:28 PM
rtucker is on a distinguished road
Check to ensure that the machine is cummucating in ASC rather than EIA. Years ago a had the same problem with K & T EB's that would only show text messages while in ASC II.
Old 09-23-2003, 11:32 PM
Have come to find out this machine is a A controler that was ment for tape reader not RS232
comunication.
Even with the tape reader books say outright that Text in program will be ignored.
Has any one overcome this?
Tried turning on TVON and got a tape error
Tried ISO and iea and still comments ar stripped.
Thinking I might have to give up on this one
Old 02-03-2004, 03:52 PM
lesr is on a distinguished road
The OTA control does not support comments.
regards
LesR
Old 02-03-2004, 04:44 PM
Shop Rag is on a distinguished road
I had the same problem with a Sharp vertical mill with an O series control. It would not accept any macro type programs. I had to set the communication settings to ISO=1, TV ON=0.
Old 04-22-2005, 01:15 PM
Victor Martin is on a distinguished road
I also have a wasino turning ctr.1982 w/ live tools and a fanuc 6t controller .I am trying to turn on the spindle in the daily startup sheet w/ no luck it just stays in neutral gear.I guess I need a fanuc 6t book. Where can I get that?
Old 04-22-2005, 01:50 PM
Al_The_Man's Avatar
You will probabally need the Wasino Service book as the gear change routine will in all probability be a Wasino designed control not necessarily Fanuc. It may not be seeing a confirmation limit switch or other sensor for in gear, unless its stuck half-way over.
Al
  #11   Ban this user!
Old 05-21-2005, 08:56 AM
Angry Wasino 1982 trn ctr w/ live tools+Fanuc 6t cont.L5-J3.
I now have a wasino book and have borrowed 2 fanuc 6t books but they dont overlap.I couldnt start the spindle in the daily startup procedure but now I figured it outt with the help of the former owner. The fanuc books were presuming I didnt have live milling heads on the turret.m.The other problem the 3 books dont cover is macros like g 70 and 71 or g 76 or g 92,etc. (2 lines or 1)I did order a fanuc macro book that should solve that from amazon.If anyone needs to know how to start a wasino spindle I can tell them-Victor
  #12   Ban this user!
Old 05-26-2005, 01:42 AM
SFA SFA is offline
SFA is on a distinguished road
Comments Enabling
There is a parameter on most Fanuc controls that determine if comments ( ) will be displayed and read. I will be happy to review a manual for you and have you check the paramter.
Greg Mercurio
Shop Floor Automations, Inc.
www.shopfloorautomations.com
(619) 461-4000 Tel
Fanuc 3M DNC operation max_c General Metal Working Machines 3 07-04-2010 08:11 PM
Fanuc CNC controler zekk_2 Servo Motors and Drives 19 02-27-2008 02:46 AM
Fanuc motor ??? jevs Servo Motors and Drives 3 03-16-2005 05:47 PM
Fanuc 21-GA_416 Alarm-Axis Disconnect lasermike Machine Problems, Solutions , Wireless DNC, serial port 0 03-10-2005 01:49 AM
FANUC coding compatability?? m1911bldr TurboCNC 3 04-24-2004 06:10 PM
