Results 1 to 4 of 4
Thread: Fanuc 31i with Z and W axis
    Registered tsaladyga's Avatar
    Aug 2009
    Hey guys,
    We recently upgraded our Gantry mill from an old Allen Bradley Control to a Fanuc 31i Control. Only, we have a "W" and a "Z" axis. Most of our parts, we postion, then lock the "W" axis, then let the "Z" do the moves, however, some of our bigger parts requires the "W" axis to do the moving instead of the "Z". On the old control, this was handles by a "G" code telling the machine to switch from "Z" to "W". I cannot find anything like that on this Fanuc control. Can someone please help!
    Thanks,
    Todd
    Registered fordav11's Avatar
    Aug 2011
    Fordaville
    there are standard parameters which allow you to name any axis with a letter in the range X Y Z A B C U V W. on the 31 series this parameter is 1020 but also check the other axis parameters (1000 to 1031)
    when you say lock do you mean clamping a rotary axis? there is usually an M code for that for A B C axis.
    you should probably start by naming the axes to a more standard layout XYZ for sliding movement and ABC for rotary movement. an M code to clamp an axis is usually specific to the machine and would likely be part of the PMC/Ladder and done by the machine tool builder (MTB)
    Jul 2010
    south africa
    Smile
    W-axis would be configured as a parallel axis to Z and is treated as a normal axis, so you don't need a switching command, just program W as you would with Z.
    May 2012
    India
    Axis disable in fanuc 31i-model A5
    Hai ,
    i wann to know how to disable the axis in fanuc series 31i model A5
    while doing some of the machine job i am in need to disable the axis which should not use at that time or permanently
    Please suggest me the procedure for disabling the axis may be W and B axis
    Thank you and waiting for the earliest reply
    Murthy
    Quote Originally Posted by fordav11 View Post
LinkBacks (?)
  1. Replies: 0
    Last Post: 01-14-2012, 04:21 AM
  2. Replies: 1
    Last Post: 11-11-2010, 01:42 PM
  3. Need Help!- synchronize Y-Axis and V-Axis on Fanuc 160i-MA
    By Larglam in forum Fanuc
    Last Post: 07-19-2010, 10:11 AM
  4. Newbie- Fanuc 21mb 4+1 axis want to make 5 axis
    By rebirthauto in forum Fanuc
    Last Post: 09-17-2008, 08:47 PM
  5. Fanuc OM-C 4th axis?
    By TR MFG in forum Fanuc
    Last Post: 01-17-2008, 01:39 PM
