Results 1 to 10 of 10
Thread: Connecting a Faunc11m to a laptop with 25pin centronics
    May 2012
    uk
    Hi, I am new to this so sorry if it's been done before or in the wrong place. Not really sure what to look for!
    I have been tasked with trying to talk to a CNC machine with a Faunc11m controller. All Dutch to me! I have an oldish Windows XP Toshiba laptop with a 25pin centronics port, the people who's machine it is have emailed me some software called ONEDNC which I have installed on the laptop.
    Any pointers? Should I use a standard 25pin - 25pin cable ? I have a 25pin - 9 pin converter if that is easier. Baud rates and other settings? Any things I really should not do?
    Any information would be gratefully received.
    Many thanks.
    Dec 2003
    If you want to send me a email add via P.M. I can send you the Fanuc RS232 manual for the 10/11.
    I generally use a 3 wire cable with the Handshake jumpered out on each end.
    The pdf is for the 0m so ignore the para, but the wiring applies.
    Attached Thumbnails Attached Thumbnails Connecting a Faunc11m to a laptop with 25pin centronics-fanuc-0m.pdf
    Registered dcoupar's Avatar
    Mar 2003
    Quote Originally Posted by 121itservice View Post
    Many thanks.
    I would not plug a cable between the "centronics" port and the machine. Centronics ports are usually only on printers, not pc's.
    If it's a DB-25 on a laptop, it's probably a parallel printer port. You need a serial port, which are usually DB-9 female. Does your laptop have one of these?
    May 2012
    uk
    Hi Al_The_Man, many thanks, I shall send you a PM.
    dcoupar, yes, it appears it is just parallel port. It's been a long time since I used such technology and for some reason forgot that it's called a parallel port for a reason!! I have a different laptop with a 9 pin serial port so will use that one instead!
    Any more info appreciated
    May 2012
    uk
    Me again!
    Al, is there any advantage of using one cable over the other? Can I just use an off the shelf null modem cable? will it matter about the handshaking lines?
    Thanks again for your help.
    Registered fordav11's Avatar
    Aug 2011
    Fordaville
    the handshaking is important. please do a search for 'RS232' or 'transfer cable'. there is a lot of info on cables and hook-ups here. No point re-inventing the wheel. It's all here just read it.
    start here maybe....
    Fanuc 6M model D !
    or here
    http://www.machinetoolhelp.com/Appli...nications.html
    etc
    May 2012
    uk
    Thanks for that, I asked because Al_the_man said he uses a standard cable with the handshake lines jumpered.
    I shall have a good read.
    Aug 2011
    Fordaville
    a standard cable may work but essentially you need to make a CNC transfer cable.
    A cable is a cable. it's just wire and connectors. the important part is where the wires go. so you can use any cable and just hack it up and re-wire it to suit your application. the handshaking part is the 'jumpers'. the 2nd link I posted gives the wiring for a 9 pin to 25 pin cable and is a good place to start when making the cable.
    Dec 2003
    Fanuc uses software handshake for control, the H.W. handshake is required but not used for control so I have always used the jumpered 3 wire version with no detrimental effects.
    Manual sent.
    May 2012
    uk
    Please disregard this post, I have solve the latest problem!
    1. Newbie- rs232.. 25pin to DB9?
      By spitfire3287 in forum Fanuc
      Last Post: 02-25-2012, 05:56 PM
    2. Bridgeport Series II Std with Centronics convert to steppers
      By caden in forum Bridgeport and Hardinge Mills
      Last Post: 02-01-2011, 03:25 AM
    3. Problems connecting laptop to TNC370
      By iknownothing in forum Bridgeport and Hardinge Mills
      Last Post: 01-24-2008, 07:26 AM
    4. MasterCam Post for Centronics M15
      By Andy Fritz in forum Post Processor Files
      Last Post: 02-19-2006, 11:14 PM
    5. Need help connecting laptop to CNC
      By flyguy1254 in forum General Metal Working Machines
      Last Post: 10-20-2004, 07:28 PM
