Results 1 to 12 of 12
Thread: Fanuc 18 M not powering up
    Jun 2008
    Question Fanuc 18 M not powering up
    Hello, we are working on a Femco BMC-110 with a Fanuc 18 M Not powering up, when we turn on the main breaker the screen says Input search then Graphics is ready, waiting serial bus is ready then goes black, this happens before the on button is pressed. On the power supply the green status led is on, on the main board all green status and all the red alarm leds are on, and on the option board 2 all green are on and the 3rd red is on. This all happens as soon as the main breaker is turned on. Please help I need to get this running asp. Thank you
    Apr 2009
    Does the screen stay dark? Is there a 'control on' push button?
    Jun 2008
    Yes the screen stays black, and yes there is a power on button on the control all this happens before the button is pressed. Screen shouldnt turn on untill after the button is pressed.
    Apr 2009
    That confused me too. Which model 18 do you have? Look at the MAIN CPU model # at the bottom of the board. The problem could be the control powersupply (right hand most board) or the 'ON' pushbutton/wiring.
    Jun 2008
    It's a B model, and I guess I should have said this happened while the machine was on.
    Apr 2009
    Please clarify: the control was ON, suddenly the screen went blank, after powering the machine off/on, the screen says Input search then Graphics is ready, waiting serial bus is ready then goes black; this happens before the control ON button is pressed? What happens if you then press the control ON button?
    Jun 2008
    Yes the contol was on when the screen went blank thought it was the monitor powered of to check it. When I press the power on button nothing happens,But if I hold the control off button while turning on the breaker get the same message on the screen
    Jun 2008
    Ok I pulled the power supply out to look at it stuck it back in turned on the main breaker the only led on was on the power supply, pushe the control on button In put search cam on the screen then the screen came on for about 3 seconds then whent blank again, and the #1 green led is on
    Apr 2009
    you could have a control problem; I am puzzled why no other leds are on. I don't know what to suggest without being there.
    Aug 2010
    If I understand it correctly, your CPU is halted or not started. The 3rd led on the option pcb is the key. what is the option board. could be a servo fault or bad i/o link. sent you a private message. what is the status of the drives?
    Mar 2012
    indonesia
    i have experience with fanuc 18 and with that problem, maybe it same problem with yours. i think that problem is in power supply unit inside the i/o board.you can try that, maybe its work.
    Oct 2009
    Mexico
    Quote Originally Posted by ofan View Post
    I would agree with ofan. You have a problem in the power supply. Just remember that the power supply has the battery for the main cpu, so that if you send it to repair you will loose memory.
    Regards
    Alex
    1. Need Help!- G540 not powering up
      By Turbo1zz in forum Gecko Drives
      Last Post: 11-18-2009, 11:00 AM
    2. Need Help!- Problems Powering on Fanuc 0M
      By LukeJohnson in forum Fanuc
      Last Post: 10-06-2009, 01:29 AM
    3. Need Help!- powering up hardinge DV-59
      By logos in forum General Metal Working Machines
      Last Post: 07-07-2008, 08:10 AM
    4. powering down the control
      By Joe Miranda in forum Milltronics
      Last Post: 04-12-2008, 09:48 PM
    5. Fanuc OT-C Not Powering Up
      By JerryH in forum Fanuc
      Last Post: 08-22-2007, 07:34 AM
