the possible problem will be with PMC parameters. most of that stuff controls machine-specific things. check your PMC parameters.
to trace the ladder you will probably need the ladder manual that was supplied with your machine because the ladder in the machine usually has no labels. the printed manual usually has text labels for each ladder step so its easy to find what you are looking for.
LinkBack URL
About LinkBacks
