Results 1 to 12 of 12
Thread: Fanuc 16-M -> won't feed when spindle is keylocked
    Feb 2011
    We have a horizontal machining center with a Fanuc Series 16-M control. We need to back-chamfer (plunge) a hole, so we keylock the spindle, position in X & Y so we can feed through the hole, we feed in the Z-axis through the hole to get to the back, then we want to feed to the centerline in the Y-axis, start the spindle, feed in the Z-axis to desired depth, then reverse the process to get out of the hole.
    The machine feeds no problem in the Z-axis with the spindle keylocked, but won't move in the X or Y-axis. Is there a parameter I need to change? Or is there another way to get through this? I'm stuck and the machine is down any help is very much appreciated...
    Registered dcoupar's Avatar
    Mar 2003
    Have you tried the G87 Back Boring Cycle?
    Feb 2011
    No I haven't tried the G87 cycle although that is probably a good idea.
    What I did was change it to rapid (G0) instead of feed (G1) and it worked.
    Mar 2003
    Quote Originally Posted by pwilson101 View Post
    You didn't specify the machine make, but I know on some Doosan's/Daewoo's they have an M-code to allow it to feed with the spindle stopped. Maybe this is the case with your machine?
    Feb 2009
    Might try with a M19 as well.
    Feb 2011
    It is a Daewoo...so there may be an M-code for feeding with no spindle? I have no M-code list for this machine, does anyone know what I can try?
    And I tried it with the M19 and it didn't work.
    Mar 2003
    What is the Model and serial number?
    Mar 2003
    You might try M84. That's the code for a DHC400, anyway.
    Mar 2007
    Some machines have a keep relay for monitoring M3/M4 basically to check if the spindle is running during a feed (G01). Do you have a list of keep relays?
    Apr 2011
    I just ran across this very same problem. What I found to fix this is parameter 3708 bit 0. Turn off bit 0 (xxxxxxx0)
    Sep 2008
    M84 will let you feed when spindle is stoped !
    M85,M30 or 'Reset' cancels it
    Mar 2003
    Quote Originally Posted by drdos View Post
    Is your machine a Daewoo or Doosan?
    1. Feed,Spindle RPM , Depth of cut
      By Pysiek in forum Benchtop Machines
      Last Post: 03-01-2012, 08:12 AM
    2. Replies: 3
      Last Post: 02-02-2012, 08:51 AM
    3. Feed rates / spindle speeds for HF spindle
      By yngndrw in forum General Metal Working Machines
      Last Post: 03-21-2009, 11:46 AM
    4. Replies: 13
      Last Post: 01-03-2009, 11:44 AM
    5. Feed (G01) with spindle off?
      By ghyman in forum Machine Problems, Solutions , Wireless DNC, serial port
      Last Post: 02-06-2007, 07:22 AM
