Results 1 to 7 of 7
Thread: Fanuc 0i-TD
    Dec 2009
    ROMANIA
    Fanuc 0i-TD
    Hi folks
    Again i need your help in a new problem and i hope we can find a solution.
    i want to make somehow on a new lathe wih fanuc 0i-TD to have a memory capacity of storage of 20gb.
    i don,t know if is possible or not but i hope someone met this problem and solve it.
    the machine has memory card slot but as far as i know is maximum 512 MB that fanuc can recognize.
    i am open for any solution or buying a new card
    i found something on the internet about the SBC-single board computers that support HDD signal acces through P2 backpanel connector but i am not sure if is ok
    u can see this attachment
    Attached Files Attached Files
    Registered fordav11's Avatar
    Aug 2011
    Fordaville
    even the latest controls don't have that much storage. not even as an option.
    why do you need 20GB in the controller?
    Dec 2009
    ROMANIA
    this machine is for one client and he wants with 20gb memory and i don,t know why he wants this.
    Aug 2007
    uk
    Better to have the files uploaded via the ethernet connection.
    They can all be backed up safely ;-)
    Aug 2011
    Fordaville
    hmmm, the client needs some education about what is possible and what is necessary.
    its better to store programs on a PC. the ethernet option may be the best way to have direct access to them.
    Jun 2012
    Romania
    hi. i have a problem too. i have a machine t250 - oi-td and i want to make it work via ethernet. i made the connection, i see files from ftp server that a installed on a computer.so the files that i see i cant manipulate them. for example i want to do a copy paste from network into the cnc. i does not appear in the lower menu nothing that helps me. i read somethhing about two things. one: to be activate the edit mode(i saw a button wich is you see edit on it) and second:the parameter 20 must be equal to 5 .(default the i/o parameter is 4 for card memory) the problem is that i can t modify that parameter. it says is write protected. how can i eliminate that write protect. sorry for my bad english.
    Registered dcoupar's Avatar
    Mar 2003
    Quote Originally Posted by Balexandru View Post
    You can change that on the SETTINGS screen. I/O Device=9 for Embedded Ethernet, 5 for Data Server. My guess is you have Embedded Ethernet.
    1. GE Fanuc & FANUC proprietary posts
      By CNCadmin in forum Fanuc
      Last Post: 03-20-2013, 10:54 AM
    2. Need Help!- Fanuc 5S servo tuning on Fanuc 15TF
      By rai in forum Fanuc
      Last Post: 02-05-2012, 05:38 PM
    3. Replies: 5
      Last Post: 03-09-2011, 10:11 AM
    4. Fanuc & GE Fanuc Repairs
      By RRL in forum Product and Manufacturer Announcements
      Last Post: 10-01-2008, 01:42 PM
