Old 12-01-2005, 03:40 AM
Hofi is on a distinguished road
Question fanuc ot multiple lead threads
Hello all,
Has anyone an Idea if it's possible to program a multiple leaded thread, on a turning machine controlled by a fanuc ot controller.
thank you for you help,
hofi
Old 12-01-2005, 08:27 AM
Chris D's Avatar
Chris D is on a distinguished road
Originally Posted by Hofi
Hello all,
hofi
Do you mean mult-start thread?
Old 12-01-2005, 08:39 AM
exactly a thread with two startpoint's ...
Old 12-01-2005, 08:47 AM
Dan Fritz is on a distinguished road
Multi-lead threads
All you need to do is back up the starting point of the threading cycle by 1/2 of the thread lead.
All Fanucs use a "zero pulse" in the spindle encoder to start the threading pass. The zero pulse happens at the same spindle angle each time, so all you can do is shift the start point in Z to get your second threading pass that's 180 degrees out from the first pass.
For a 10 pitch thread, you have .1000 per revolution, so back up the Z start point by .0500 and cut the same threading cycle, using the same Z as the end point.
Old 12-01-2005, 08:51 AM
Thumbs up
Thank you very much, i definatly give that a try .........
Old 12-01-2005, 07:44 PM
cogsman1 is on a distinguished road
Multi start threads
Feed rate will be PITCH x # of starts
Each start will back up one pitch
Exam:
3 start thread
32 tpi = .0313” pitch
feed = 3 x .0313” = .0938”
start 1st thread at .050”
second thread at .050” + .0313” = .0813”
third thread at .0813” + .0313 = .1126”
T0500
S1=2000M3
G0X.238Z-.05T5
G4U.5
G76P010015Q.003R.001
G76X.0996Z.8P.0192Q.0083F.0938
G0X.238
Z.0813
G4U.5
G0X.238
Z.1126
G4U.5
G0X.238
This would do a 3 start 32 pitch OD thread.
