Results 1 to 3 of 3
Thread: What to look for with bar feeder
    Mar 2010
    I just brought a Takisawa TC-20 which has a Fanuc 21 T controler. Also fitted is a BarTec bar feeder. As I understand it, it was all working at the last site my issue is that there are no manuals for the bar feeder and I can,t get much info fromthe previous owner as to how it was call from the program. Al I do know is that if I change tool I must start with M22, have no idea why.
    Could some one offer a bit of a over view as to how bar feeder are called or programed with in the program and if possiable what I should look at in the program to find out how it was operated.
    Thanks.
    Tony
    Jan 2012
    America
    OUR TAKI BAR FEED PROG
    OURS STARTS WITH THE CUT-OFF TOOL LIKE THIS
    M01
    G10P03R.0312Q3
    G50S1350
    G96S200M03
    T0101
    M08
    G00X1.6Z.02
    G75P250X.120F.0025
    G00X4.0M09
    M00(GET PART)
    T0101
    G96S200M03
    M08
    G00X1.6
    G01X.160F.01
    G01X-.015F.0025
    G00X2.0M09
    G00X6.0Z6.0
    M01
    THEN ENDS WITH THE BAR STOP LIKE THIS
    N1000
    M05
    M09
    IF[#1011EQ1]GOTO50
    T0202
    G00X0.0Z1.187
    M69
    M00
    M68
    G04U1.0
    G00X8.0Z3.0
    T0200
    M01
    M99
    N50
    M68
    M30
    HOPE THIS HELPS
    Mar 2010
    Hi Recordhound,
    Is your the same type, the code seems to make sense as it appears to be the same as the bit I still have.
    Thank you very much.
    Tony
  1. Need Help!- using bar feeder
    By laamar in forum Haas Lathes
    Last Post: 11-25-2011, 11:23 AM
  2. Need Help!- bar feeder manual
    By Jfrahm in forum General Metal Working Machines
    Last Post: 04-22-2011, 11:12 PM
  3. Problem- Servo bar 300 bar feeder
    By dthiede in forum Haas Lathes
    Last Post: 08-27-2010, 08:35 AM
  4. CNC BAR FEEDER
    By hiiesalu in forum Linear and Rotary Motion
    Last Post: 05-13-2009, 06:51 PM
  5. MTA 541 Bar feeder
    By DocHod in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 10-02-2007, 11:03 PM
