Results 1 to 12 of 12
Thread: Where to buy fanuc oi in the us
    Mar 2009
    chile
    Hello,
    i want to retrofit a bridgeport type knee mill, with fanuc controls, drives and servo motors. I dont know where I can quote it, in the us.
    I was thinkng in 0i-Mate or 0i-MC, what is an estimate cost for these kits, wich one is more recommended . i don't want to install servo for the spindle .
    thank you
    Feb 2009
    1-888-fanucus...
    kinda of overkill and expensive for a bridgeport IMO.
    Mar 2009
    chile
    what is your recommendation for this type of mill?. mi idea is to install this kit and then sell the machine. i want something very reliable.
    Dec 2003
    Initially I wanted to use Fanuc when I started out, Personally I found Mitsubishi much better to work with when I got into retrofits, Fanuc didn't seem to want to know unless you are an OEM, Mitsubishi was like night and day.
    Depending on what help you can get in your area, I would also look into Anilam and Fagor, before I went with Fanuc.
    Mar 2009
    chile
    do you know how much a Mitsubishi system could cost? which series of Mitsubishi would you recommend?
    Dec 2003
    I am not sure which is the cheaper units now, I used to use the popular M50, it was around $8k-$10K if no spindle included.
    Mar 2009
    chile
    what is your opinion about going with the machmotion servo kit?
    Dec 2003
    Well it IS a cheap answer, but no comparison to a Industrial control.
    What ever you go with I would definitely recommend servo's.
    You might want to look at Dynomotion Kflop/Kanalog as well.
    Feb 2009
    Lower cost, im sure Al's price was control only. Please correct me if im wrong Al, but 10K for the control, and another 10k ? for 3 axis motors and drives.
    I would look at the Ajax all in one, with Yaskawa servo motors/drives and a Mach 3 front end.
    Bet the Fanuc with motors and drives will be way over 20K.
    Dec 2003
    I never paid more than $14k for Mitsubishi system, I may have had special pricing as I was set up as an integrator?
    A few years back Mitsubishi used to dump older models of CNC and VFD's on ebay, complete lathe packages were going for $7k. They would upgrade to mill for minimum chge.
    I was buying VFD's by the pallet load at the time.
    I believe they got feedback from upset distributors, as they no longer have the ebay account.
    At the time I paid big $$'s for Fanuc courses, Mitsubishi's were free, as long as you made your way there.
    Mar 2009
    chile
    Hi Al,
    if i chose to go with ac servo drives + break out board + pc + mach3.
    do i need anything else?.
    i have a limited budget (5k to 6k).
    which servo and breakout board would you choose?
    thank you.
    Dec 2003
    I don't use Mach at all so it might be best to post the question in the Mach forum.
    1. GE Fanuc & FANUC proprietary posts
      By CNCadmin in forum Fanuc
      Last Post: 03-20-2013, 10:54 AM
    2. Need Help!- Fanuc 5S servo tuning on Fanuc 15TF
      By rai in forum Fanuc
      Last Post: 02-05-2012, 05:38 PM
    3. Need Help!- Difference between Fanuc 0i-MC and Fanuc 0i-MD
      By humak16 in forum Fanuc
      Last Post: 12-29-2011, 11:49 PM
    4. Replies: 5
      Last Post: 03-09-2011, 10:11 AM
