Results 1 to 6 of 6
Thread: Need to change timing on chip conveyor.
    May 2007
    Eurotech Biglia B658SL-Y with 18i-TB control. Owner at my second job doesn't read Italian. Said he has tried a web translator, but still doesn't understand it. He wants to shorten the distance the conveyor travels, and increase the time between movements. Anyone out there have an idea where to make the changes? Told him I would try to find out.
    Thanks.
    Mar 2012
    indonesia
    have u check the ladder?u check the timer number that use for chip conveyor
    Registered dcoupar's Avatar
    Mar 2003
    You might try these guys:
    Our Staff/Contact Us
    May 2007
    Quote Originally Posted by ofan View Post
    I'll have to ask the owner if he knows where that is. Thanks.
    Quote Originally Posted by dcoupar View Post
    I will pass the link along. Thank you also.
    Jun 2010
    Cool Pretty Simple
    I am running a B465 y2 eurotech with an 31i
    The controller has it's own timer page.
    1. press setting key
    2. right softkey to pmc maintence and press the softkey under it.
    3. press softkey under timer
    You should see a chart with different 1000 numbers you can alter (milliseconds)
    Parameter#6 is conveyor OFF duration
    Parameter#7 is conveyor ON duration
    No one seemed to know about the timers so i sat at my machine with a stop watch and kept track of how long things would run and then how long they were off. I then jotted them in my notebook. Like I said before, they are milliseconds so 1000=1 second....60000= 1 min. etc.
    Hope this helps!
    May 2007
    Thanks a bunch. It is a big help.
    1. Chip conveyor for LB15
      By cad01 in forum Okuma
      Last Post: 12-09-2011, 11:11 PM
    2. Need Help!- puma 160 chip conveyor
      By driftbuster50 in forum Daewoo/Doosan
      Last Post: 04-20-2011, 09:03 AM
    3. Chip conveyor on 6030
      By 5th-axis in forum Fadal
      Last Post: 12-06-2010, 08:51 AM
    4. 4020 chip conveyor?
      By MBX5 in forum Fadal
      Last Post: 08-26-2010, 11:09 AM
    5. Where to get chip conveyor belt material?
      By SRT Mike in forum General Metal Working Machines
      Last Post: 10-20-2006, 05:37 PM
