Results 1 to 4 of 4
Thread: Rotary table integration
    Registered vincent.pomerleau's Avatar
    Feb 2010
    Question Rotary table integration
    hello
    I just finished installation a a rotary table on my VMC.My control is a fanuc 18i and and my motors are also alpha i. All seem to work great, the positionning are perfect, the speed is good for a 16" rotary (14 RPM).My problem is when i'm at A0 and i call G0 A180. it took 3-4 degrees to reach it's full speed of 5000 degrees/min and it's nice for me but if i call G1 A180. F3000. ,the rotary start really slow to reach it's speed at about 90 deg.and decelerate for the other 90 deg. Unthinkable to do 4axis simultaneous! All the A axis have brand new material(motor,drive and cables. I cheked for the accel/decel parameters and motors parameters, all values look like the other axis and i think it's my problem...some value probably need to be really different becaus its a rotation axis...
    Any help will be really appreciated
    Feb 2010
    I forgot to mention that when i use jog or the manual hanwheel al is good it accelerate instantly!
    Feb 2010
    Or there's someone who can give me his parameter file for a 4 axis VMC with fanuc 18i-mb for compare them to mines???
    Feb 2010
    solved! parameter 1631 if someone is interested!
  1. Need Help!- Rotary Table Help
    By Crashmaster in forum General Metal Working Machines
    Last Post: 03-27-2012, 10:45 AM
  2. Need Help!- CNC Rotary Table
    By KJ45 in forum General Metal Working Machines
    Last Post: 07-09-2010, 07:35 AM
  3. How do you use a rotary table?
    By ranchak in forum General Metal Working Machines
    Last Post: 01-30-2008, 11:30 PM
  4. rotary table
    By bulletfab in forum Haas Mills
    Last Post: 12-16-2007, 03:48 PM
  5. Useful for Rotary Table?
    By Ken Stuempge in forum Mechanical Calculations/Engineering Design
    Last Post: 02-12-2006, 10:16 AM
