Page 1 of 2 12 LastLast
Results 1 to 12 of 20
Thread: operating system and ladder
    Mar 2012
    Fanuc 18 ,
    I would like to know more about the operating sytem for the control, and how it differs from the PMC ladder logic?
    I have a friend that is trying to figure out how to change the cnc programs
    with in a program. That is not using sub programs, ie M98 etc.
    How is the number changed the normal manual way? Is it done by the PMC? What address etc?
    Does fanuc offer any online classes? Don't have time to travel to a class.
    Registered tc429's Avatar
    Feb 2011
    need to read the macro section in the operators manual- thats about the only way you can program inside a program...
    Mar 2012
    Quote Originally Posted by tc429 View Post
    Been there done that. I use macro's daily. If a macro is to be used I need the variable to put the program number in to activate it.
    Registered fordav11's Avatar
    Aug 2011
    Fordaville
    'program inside a program' does not make sense. what you want exactly is not clear.
    if you want to know about how the ladder works read the ladder manual. if you need info on macro variables read the macro section of the operators manual. if none of this applies you need to explain more exactly what you want to know.....
    Feb 2011
    Unless you are talking about changing parameters then macros are the only way to change program data.
    The controller does have a operating system but you dont have access to it.
    Fanuc will do what ever you want as long as you pay them for it. Give them a call.
    Mar 2012
    Quote Originally Posted by fordav11 View Post
    Hmmm that was another fellow that said the program inside a program, not me.
    I said to change the program with in a program. ie change from one main program to the next.
    The imediate problem is. When a new pallet is introduced into the machine.
    He wants to have the program, say its number is o1234
    Do this
    O1234
    G90GOG54
    G43Z1.H3
    AND ON AND ON
    ETC ETC
    G91G28Z0
    G91G28X0Y0
    M160 (PALLET CHANGE)
    #?????= O2345 <-----NEW PROGRAM FOR THE NEXT PALLET
    M30 <---- PROBABLY NOT NECESSARY BECAUSE NEW PROGRAM WOULD
    CANCLE IT FROM BEING SEEN.
    NOW THE MACHINE HAS O2345 AS THE NEW MAIN PROGRAM.
    NO SUBS ALLOWED, AS WHEN RESET IS PUSHED A ROOKY WOULD BE LOST.
    Yes I know about M98Pxxxx, what is needed, is to be able to assign a new main program, just like some multi pallet cell systems do. Just need to know what system variable to change.
    Then its simple.
    #????=2345
    How is the program number handled? If its typed into the control, the down arrow is pushed and the new program is there. Can it be done using a macro that accesses the down arrow key variable, still need to know the variable to put the number into. Why are the simple things so difficult?
    In the operators manual it does not cover many of the system variables that exist in the control. Where is a good address or phone number to order the manuals at? I would like to know how to relate the various alphabet addresses to their variables. And how to relate them in the ladder as well. Its all pretty vague in all the info.
    The ladder priciple is not too difficult to grasp, its the addressing and how the various logic relays are turned on and off, and how it relates to variables and the alphabetic addresses. Thats whats confusing, how does it relate to say the diagnostic page with the ons and offs? Say you have an X12.3
    where is that in the ladder in an 18i?(search shows not found in ladder) And what is the system variable for it? And how is it all figured out. I thank all of you ahead of time.
    Okay X is input signal so maybe there is no system variable????? Do system variables only exist for F addresses? I really need a good book on the subject.
    In the ladder there are boxed subs??? Is the diagram for them just below them? I know, sorry just a mess of questions I have.
    Mar 2012
    Quote Originally Posted by jimmy111 View Post
    Nothing is learned that way. Unless they want to hire me, but I only travel in a 30 mile radius.
    And when you work for a place that sometimes cann't find the funds for the simple stuff, its a hard sell for something the upper ups can't even understand.
    I need a good 1-800 number for them. I want to purchase some manuals.
    Jul 2007
    Aug 2011
    Fordaville
    you can't just switch programs using O inside a program.
    the only way is calling programs using a sub (M98)
    All of the macro system variables are covered in the manual. You need to actually read the manuals instead of ranting on about how bad the manuals are (which you have clearly not read)
    in any case what you want can't be done. you can't send keystrokes to the machine from a program (O1234 down arrow search etc). if your people can't handle subs hire smarter people.
    Feb 2011
    Why would you want the machine to write a new program?
    But anyhow it can be done if your controller is capable of it. Read the macro manual and get Smids custom macro book.
    Feb 2011
    you can 'press keys' via a variable- the mdi keypad is somewhat accessible with 'external key input option', the keys are mapped as g- addresses in the ladder- you could use the #1032/#1132 words to move sequences into/out of the ladder to change screens and whatnot, but it would be messy to figure out. I played around with a similar app years back, found it was easier just to write the macro...we had a hines balancer feeding imbalance info into a mill that touch probed/mapped balance pads and cut requisite amounts fed in from the hines...was fun, but pressing cycle start executed a 13 page macro, took several seconds for machine to move
    anyways, why not always just run program1, and m98p#500 or something like that? you can change 500 at will, and its battery backed in case of restart, so noone gets lost.
    Mar 2012
    How is a new main program called up on a muti pallet cell system? I have read the manual, operating manual, not a specific fanuc macro manual if there is one.
    I bought a fanuc macro programming book (not by fanuc) some time ago, and that author included system variables that are not in the fanuc operators manual.
    How about the address deal I mentioned below?
    M98's would be a mess on the type of work that is done in this shop. It requires too much manual intervention and program searching. Hire smarter people, I don't think they can even find dumb ones now. The Boeing boom is making cnc people very hard to come by in this area.
  • Page 1 of 2 12 LastLast
    1. Need Help!- operating system
      By Nadda` in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 01-05-2010, 09:30 AM
    2. Which operating system.....
      By T63-A-700 in forum Mach Software (ArtSoft software)
      Last Post: 12-24-2008, 04:26 PM
    3. Installing Operating system
      By millman52 in forum General Electronics Discussion
      Last Post: 10-07-2007, 11:38 PM
    4. CNC linux operating system
      By piglete2000 in forum AjaxCNC Control Products
      Last Post: 06-23-2005, 09:55 AM
    5. Choice of operating system
      By HuFlungDung in forum CamSoft Products
      Last Post: 06-12-2004, 12:25 AM
