Results 1 to 3 of 3
Thread: fanuc 0t 416 alarm need help
    Mar 2012
    thailand
    I am new to cnc. Recently, I replace pulse coder for x-axis. Everything seems to work fine. Except, sometiems when I hit estop, I get alram 416 (not every time). Anyone has any ideas what is happening and how to fix it. Help please!
    Jan 2011
    China
    Quote Originally Posted by thailatheman View Post
    The 416 alarm means"Position detection system fault in the n–th axis
    pulse coder (disconnection alarm)."So you should check the line.
    Best Regards,
    Aaron
    Banned yours_prabhat's Avatar
    Dec 2008
    India
    When you press Emg Stop During that type 24 V control Circuit break , So that time the TTL voltage of The Encoder/Pulsecoder Drops , So it forget The A A BAR Z Z BAR , Check the Feed back cable of Pulse coder at Both End , Loose connection , and +5V Vcc supply
    Regards
  1. Replies: 1
    Last Post: 12-24-2012, 06:57 AM
  2. Alarm 319 & 329 on Fanuc OT
    By rollixmac in forum Fanuc
    Last Post: 12-06-2010, 11:52 PM
  3. Replies: 1
    Last Post: 11-11-2010, 01:42 PM
  4. FANUC 0M - alarm 520
    By promech in forum Fanuc
    Last Post: 02-19-2007, 11:41 AM
  5. fanuc 11t alarm need help please!
    By tomtech in forum Fanuc
    Last Post: 01-30-2007, 06:02 PM
