Not sure if this is the one you need or not, but it's the only one I found.
0010 bit 2
1: The position programmed is displayed in the present value display
0: The actual tool poosition with tool offset and tool nose radius comp is displayed
Hi I have a Ikegai with a Fanuc 6T control and when I add my offset values my CRT adds them to the screen value so if my program was written to say GO X1.0 Z-2.0 and I add say X-.800 and Z-.500 in the offset page
CRT screen will now read the difference as
X .200
Z 1.500
NO0222 N0222
I would prefer
X 1.0
Z -2.0
NO0222 N0222
Is there a way to change a parameter so the offset value is not shown???
0010 bit 2
that's the one. it needs to be set to 1 so it shows the programmed position
hi i have ikagai 6t fanuc control machine the machine spindle dont start manual&mdi mode.i check spindle drive alarm led all led light blink checked the pcb board m,p,p1,n pin power supply,24,15,-15 volt down any help me thank you.this is imported machine i need 6t manual.
