Results 1 to 4 of 4
Thread: Programing
    Feb 2012
    united states
    Programing
    N2(BORING BAR THINBIT MBA-S37-3718R050)
    G50S3000
    G0T0202M8
    G96S600M3
    G0X.220Z.1
    G71P100Q101U.02W.OO2D150F.002
    N100G0G42X.220
    G1Z-.500X.500F.006
    N101G0G40Z.1
    G70P100Q101
    G0X.220Z.1
    G0Z8.
    T0200
    M30
    I am getting an error saying. Problem with finish shape. Anyhelp greatly appreciated. It throws the error when the g71 is read. Thanks
    Registered dcoupar's Avatar
    Mar 2003
    What is this part supposed to look like?
    May 2004
    Quote Originally Posted by mschmitz88 View Post
    G50S3000
    G0T0202M8
    G96S600M3
    G0X.220Z.1
    N100G0G42X.220
    G1Z-.500X.500F.006
    N101G0G40Z.1
    G70P100Q101
    G0X.220Z.1
    G0Z8.
    T0200
    M30
    Do what ford says below.
    http://www.kirkcon.com/
    Registered fordav11's Avatar
    Aug 2011
    Fordaville
    The start point can be the same as the first move point, it's not so important. Yes it's pointless but it's not a deal breaker.
    That program has *MANY* issues. The main ones were you are machining a pocket (tool moving to a larger diameter) and you had not enabled TYPE II canned cycles (assuming you even have the option). Then on the G71 line you have a couple of O's in the W word (the letter O, should be number 0) unless that was a typo.
    Then you are using G42 and you should be using G41. And many other little things. Compare the two programs and you will see.....
    N2 (BORING BAR THINBIT MBA-S37-3718R050)
    G50 S3000
    G0 T0202 M8
    G96 S600 M3
    G0 X.220 Z.1 G41
    G71 P100 Q101 U.02 W.002 D150 F.002
    N100 G0 X.220 Z.1
    G1 Z-.500 X.500 F.006
    N101 X.220
    G70 P100 Q101
    G0 X.220 Z1. G40 M9
    Z8. M5
    T0200
    M30
  1. need help programing
    By dek in forum Machinist Feedback
    Last Post: 04-22-2010, 03:32 PM
  2. programing G3 IJ R
    By Luslugger in forum G-Code Programing
    Last Post: 08-01-2008, 01:42 AM
  3. programing help
    By DARKWINZ in forum Okuma
    Last Post: 06-02-2008, 10:23 PM
  4. CNC programing
    By Fryzss in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 10-27-2007, 11:33 AM
  5. CAM programing
    By kenlambert in forum G-Code Programing
    Last Post: 02-03-2006, 01:03 AM
