Results 1 to 7 of 7
Thread: 15M won't start
    Jun 2011
    15M won't start
    I have a Fanuc 15M. My problem is, it will not start up / boot up. It turns on some days and some days it does not. When I press the start button you here the relay engage momentarily the fans start to turn on then it just stops. On what I believe is the power board there is a Green LED light and a red Alarm LED both lit. When I press the off button the Green LED stays lit but the Red alarm LED goes off. Does anyone have any suggestions?
    Feb 2009
    Usually that indicates a short in a 24 volt line somewhere.
    Apr 2009
    I agree. Could also be the power supply, some boards, shorted suppression diodes, wiring shorts and more. Where are you located?
    Registered tc429's Avatar
    Feb 2011
    90% of the time its coolant in a limit switch...look for the dirtiest switches, they are usually a good place to start.
    get a good DVM that will read to .01 ohm, poweroff, start checking ground to your input terminals, the lowest one is usually the culprit... a normal meter its hard to see as all the OT/Decel switches are normally closed will read under a ohm from one to the other, but using low ohms scale, you can pick up the lowest one because of the resistance/length of the wires.
    it can be anywhere, even just a bad cap on a 5v/15v supply- but limits or busted wires are usually it. sometimes you can even just sniff around- the smell of water etching away at anything electrical usually has that 'burnt solenoid/varnish' smell to some extent
    Jun 2011
    memoryman, I am from Massachusetts but currently an in ChangYi China. So getting information in English around here is not easy. I want to thank you all for your help.
    tc429 I follow you about the DVM and process. I will trace and check all the wires first then dig into the electronics. Please forgive me I am new to this, where would I find that limit switch you mentioned?
    Feb 2011
    China? let them fix it
    switches for overtravel/decel are often a Balluff or Euchner multi-plunger switch that trips at the home/end of travel on each axis, they often get coolant in them and short to ground... sometimes mounted under way covers.
    Jun 2011
    Wink
    yeah I wish , it's been a struggle, but Thank you so much! I know exactly where those limiters are. I will check that first thing in the morning.
    1. 1 start or 2 start anti-backlash nuts?
      By SpeedyDad in forum Momus Design CNC plans
      Last Post: 08-29-2011, 01:00 PM
    2. ACME rods - normal start and multi-start
      By shaffin in forum Canadian Club House
      Last Post: 12-20-2010, 08:19 AM
    3. Replies: 4
      Last Post: 01-06-2009, 11:20 AM
    4. Newbie- one start or two start lead screw
      By Pinhead in forum DIY CNC Router Table Machines
      Last Post: 11-22-2008, 11:32 PM
    5. Single start vs double start ballscrew.
      By darik in forum Linear and Rotary Motion
      Last Post: 03-21-2007, 08:53 PM
