On the 10, you can disable the soft limits on power-up by holding - and . at the same time, then press power-on. You should see an IPL menu. Key in 4, then INPUT. You should see something to the effect of "Check soft OT at power on?" Press N (for no), then INPUT. Press 6 to end the IPL. The control should boot up, and if you look at the position page, the MACHINE positions should now read 0. Try your zero return routine.
LinkBack URL
About LinkBacks
