Results 1 to 9 of 9
Thread: HELP FANUC O-MC MEMORY
    Jul 2007
    WHAT'S THE STANDARD MEMORY SIZE IN A O-MC SYSTEM?
    AND WHAT PARAMETERS DO I HAVE TO ADJUST IF IN CASE OF MEMORY
    EXPANSION?
    CAN SOME BODY TELL ME?
    THANKS.
    Sep 2007
    Mexico
    Usually the stantdard is 128K, and as far as I know that is the limit.
    GP.
    Registered tc429's Avatar
    Feb 2011
    standard on any zero is only 4k, max on a 0A is 32k, on a 0C its 100k
    Feb 2009
    There really is no "standard". It's up to the builder to specify memory when the machine is built. Some machines may have 16K, others of a different brand may have 32K as standard.
    Feb 2011
    maybe I shoulda said 'default'...until the parameters are set after all-clear, they only have 4k, even though theres min 8k ram onboard even with all empty sockets
    Sep 2007
    Mexico
    Well, all 0MC's that I have worked on have 128K, and it is never enough when you run programs for molds or big dies.
    We use the drip feed option to work with larger programs.
    Mar 2012
    Mexico
    Tha's correct it's up to the builder, i f you need to expand your memory, first check the size of your current memory; programs directory screen you'll see all the space free, And then you'll need to buy the Option including the new memory Board.
    I hope this help....
    Apr 2009
    the max on an analog FS-0 is 48k, on a digital FS-0 is 128k.
    We are looking on expanding that to 1M, possibly 2M. but only on the FS-0C controls.
    Jul 2007
    Thank you guys for all your responses, apparently I must change one of the
    900's parameters, this particular machine is not taking the same programs that use to run before they clear the memory and lost all parameters.
    1. Need Help!- Fanuc 0M Memory PCB A4
      By M.RISHIKESH in forum Fanuc
      Last Post: 07-08-2011, 09:59 AM
    2. Newbie- fanuc 11m not enough memory
      By Nikola in forum Fanuc
      Last Post: 02-04-2008, 04:43 PM
    3. Fanuc OM Memory
      By Davidimurray in forum Fanuc
      Last Post: 11-27-2007, 10:02 AM
    4. Fanuc OM-B Memory
      By Fine01 in forum Fanuc
      Last Post: 10-31-2007, 09:36 AM
    5. Fanuc 0 M memory
      By matic in forum Fanuc
      Last Post: 05-27-2007, 01:33 PM
