Cincinati Milacron Sabre X axis Referencing Problem
Dear All
We have got a Cincinati Milacron Sabre VMC which was not in use for sometime and now when we HOME all axes, as per standard sequence, X axis moves in negative direction, then deceleration limit switch gets pressed, input X8.6 becomes high, then X start moving in +ve direction, again X moves in negative direction, X 8.6 gets ON, then X axis moves in +ve direction and keeps moving in +ve direction without getting referenced and hence error Time Out ...... appears
1. We have tried by changing X axis Motor pulse coder with Y motor
2. Axes card (to which Motor pulse coder gets connected) replaced with another working machine
3. All the parameters compared with another running machine
4. Limit switch replaced with another new one
5. We have moved reference DOG in both direction by say upto 10 mm
There is no change and X is not getting referenced
