I'm trying to engrave a part number on the side of a 22mm round bar using
the Manual Guide i engraving function on a lathe + live tooling.
I've got it machining the characters in the correct place but the letters /
numbers are all mirrored vertically. ( eg 6 looks like 9 and W looks like a M etc)
The simulation is correct however.
When actually machining, it appears as if all the C axis movements are in the wrong direction.
If any one has experience with this who can help it would be much appreciated.
Thanks, Dave.
Just a follow up in case any one else comes up aginst this problem.
It's parameter 00012 C-axis bit 0 MIR needed to be set to 1
Text on the side of a bar is correct. If I get time I'll do a test on the face to see if that's ok too.
ATB
Dave.
