Results 1 to 6 of 6
Thread: Thread Mill on FANUC 10M
    Mar 2012
    India
    I am trying thread milling operation on MV40 VMC with FANUC 10M controller.
    Machine is moving in all 3 axes simultaneously in G01.
    G02 and G03 is also working in reight way.
    But somehow mahine is not moving in G02 / G03 in X Y and Z axis.
    error shown is PS186: illegal plane selection.
    i've tried G17 G03 X Y Z F also.
    following program i got through some software also doesnt work.
    Thread size is 1/4" 19 TPI BSP. 13mm thread depth. Cutter is SC thred mill
    Doing upmilling in single pass.
    G90 G00 G57 X0 Y0
    G43 H10 Z0 M3 S3223
    G91 G00 X0 Y0 Z-12.823
    G01 G41 D60 X1.593 Y-4.985 Z0 F58
    G91 G03 X4.985 Y4.985 Z0.123 R4.985 F58
    G91 G03 X0 Y0 Z1.337 I-6.579 J0 F193
    G91 G03 X-4.985 Y4.985 Z0.123 R4.985
    G00 G40 X-1.593 Y-4.985 Z0
    G90 G00 Z200.000
    M5
    M30
    Can some1 help me with this problem? is there ne necessity to make changes in parameter 9100 bit 2? or any other parameter?
    we tried this also but alarm shown is "Parameter is locked"
    Registered tc429's Avatar
    Feb 2011
    helical milling is different than 3 axis simultaneous- different option.
    9100s can only be changed in hex thru IPL after the 3 passwords
    Mar 2012
    India
    can you tell me how to change the "locked parameters"?
    Mar 2012
    India
    @ tc429
    Read your earlier post regarding changing 9100 in hex.
    thanks for the help !!
    Feb 2011
    yeah, Ive seen a couple times where a maint guy tried to type in that stuff after a dead battery and forgot about the IPL/hex thing... if I had to reload one today after a dead battery I'd have to go online digging for the password numbers to get the 'OP1=?' to pop up... havent touched a 10/11 in a long time
    Feb 2006
    canada
    post it out in line segment with arcs. mastercam will post it like that. I run a 2005 mazak msy 250 and the do threadmilling without the c-axis id would have to use line segments.
    1. staggered thread G76 on Fanuc 0i
      By kkronja in forum Fanuc
      Last Post: 07-23-2012, 06:11 PM
    2. Need Help!- G76 thread on Fanuc oi-t control
      By taz345 in forum Fanuc
      Last Post: 03-16-2009, 08:23 PM
    3. Thread mill external NPT thread
      By cutting edge in forum General Metalwork Discussion
      Last Post: 09-15-2008, 09:33 AM
    4. thread cutting FANUC 0i TB
      By xavierdemoura in forum Fanuc
      Last Post: 09-23-2006, 09:07 PM
    5. thread chamfer on fanuc 21t
      By mci1960 in forum General Metalwork Discussion
      Last Post: 04-25-2005, 01:25 AM
