Results 1 to 3 of 3
Thread: tool position not zero at origin (no offset used!)
    hfk
    hfk is offline
    Jan 2011
    netherlands
    Machine: 1981 Mazak VMC Fanuc 6MB control
    I have a strange problem with tool lenght measuring. I measure my tools from a fixed block on the tool table. I use G59 for these coordinates. My edge finder is my reference tool. I put my height gauge on the block and touch off. The Z-Machine position is put in G59 Z-offset, so the Z-absolute should be 0.
    Whithout any offset, my z-position now is +3.854 [mm]. What is going wrong?
    It has worked well in the past.
    To complete:
    -no Z offset is used
    -machine is zero-ed correct
    -it worked in the past
    -I didn't mess with any parameters in between
    PBr
    PBr is offline
    Jan 2006
    SLOVAKIA
    I had a similiar problem with coordinates - check the "absolute manual" setting on your machine.
    hfk
    hfk is offline
    Jan 2011
    netherlands
    you mean the toggle switch 'manual absolute'?
    Already had that problem when I was trying to get the work coordinats G54,G55 etc to work. This is different. I can check after the weekend, but other things work fine. When I offset all tools from the reference tool it works perfectly, but the Z-coordinats are all shifted.
  1. Need Help!- Machine Origin Position Setting (Belt Broke)
    By obieron in forum CNC Swiss Screw Machines
    Last Post: 09-22-2011, 07:14 PM
  2. Adjust origin offset in Biesse Rover B FTK
    By PieriWW in forum CNC Machining Centers
    Last Post: 05-11-2011, 02:56 PM
  3. Tool ATC arm Origin
    By Kool Parts in forum Haas Mills
    Last Post: 11-03-2009, 01:58 AM
  4. Newbie- Origin and tool offsets Lathe
    By Bony Fingers in forum Daewoo/Doosan
    Last Post: 04-15-2009, 01:36 AM
  5. found a xyz origin position
    By mcfelix in forum General Metal Working Machines
    Last Post: 04-04-2006, 03:01 PM
