Results 1 to 3 of 3
Thread: fanuc 11 "L" error and masterboards revisions
    Registered guhl's Avatar
    Aug 2007
    Ukraine, Sevastopol
    My old masterboard A16B-1010-0330/11A comes to senses only after heating of the part of PCB and operates. Axеs running.
    Installed another masterboard A16B-1010-0330/10A shows "L" and on screen I see "PC PARAMETERS LOAD:END", though all additional PCBs(memory, etc.) works fine.
    In what difference between 10A and 11A revisions?
    nothing to say under this line
    Apr 2009
    usually the board revision # only matters if you replace a board with an lower #, as you did, but I have never had a problem doing that. Did you check for jumpers? Was the /10A board a known good one?
    Aug 2007
    Ukraine, Sevastopol
    I think I know what the difference is:
    on 10A two driver ICs are soldered, and on 11A they are in the sockets
    this masterboard doesn't have the jumpers
    I don't 100% sure that this PCB is a good one. now try to test it
  1. Replies: 6
    Last Post: 08-15-2011, 04:23 PM
  2. Problem- "master encoder state error" AB ultra100 error message
    By ShapeShaver in forum Servo Motors and Drives
    Last Post: 08-06-2011, 07:39 AM
  3. Mazak T-2 "20 NMI Emergency Stop" Error"
    By Jeff_Y in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-11-2011, 11:35 AM
  4. Mechanical Desktop "Error - Incorrect Object To Bind - T"
    By CNCOX in forum Autodesk Software (Autocad, Inventor etc)
    Last Post: 11-23-2009, 05:45 PM
  5. V2XT error message "DRIVE FAULT detected (0,z,y,x) check log"
    By rfdoyle in forum Bridgeport and Hardinge Mills
    Last Post: 10-08-2007, 04:35 PM
