Results 1 to 2 of 2
Thread: M5 turns off coolant. Is there a parameter to change this?
    Registered MCImes's Avatar
    Sep 2011
    Question M5 turns off coolant. Is there a parameter to change this?
    Hello,
    The idiot engineer at Tsugami decided that M5 should turn off the spindle AND coolant *facepalm*. Is there a parameter to disassociate these 2 actions? or is that written into the ladder?
    It wold be nice to be able to write M5 instead of S0. When you command S0 the spindle motor tries to hold the position that it stopped at and alarms out if you move it even by hand which normally doesnt matter but for setup it can be annoying.
    Its a 18i-TB control if it matters.
    Process Development machinist / CNC training consultant
    Registered guhl's Avatar
    Aug 2007
    Ukraine, Sevastopol
    look into ladder. may be turning off keeprelay just needed
    nothing to say under this line
  1. sqt-15 sporadically indexes turret and coolant turns on??
    By CGREGORY in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-08-2011, 09:27 AM
  2. Problem- Change parameter
    By 1983CRAZYBB in forum Haas Mills
    Last Post: 03-10-2011, 11:06 AM
  3. Need Help!- Change parameter 5101
    By jdgromi in forum Fanuc
    Last Post: 04-03-2009, 07:57 PM
  4. Parameter change
    By adamant in forum Fanuc
    Last Post: 05-28-2008, 12:37 PM
  5. Tool Change Parameter
    By Jason812 in forum Fanuc
    Last Post: 11-20-2007, 08:29 PM
Visitors found this page by searching for:
Nobody landed on this page from a search engine, yet!
SEO Blog
