In what way is it not working well? Normally the issue is when you need a copy of a Tool Change Macro is when you don't have it at all. If you have a Macro program that once worked, problems more likely occur through proximity switches not being made during the tool change sequence. With the Umbrella type tool changer on the Leadwell machines, there is a bit of interaction between the Macro program and the PLC via the interface System Variables.
Unless you're missing the Macro program all together, or you know for sure that the one you have is corrupt in some way, another Macro program may not help.
If you post the one that you have, I, or someone will be able to tell you if its OK, but it will definitely be helpful for you to describe the problem.
Regards,
Bill
LinkBack URL
About LinkBacks
