Need to know parameter number for stroke limits. Need to know what numbers in these parameters represent (on/off or actual positions)
and if these parameter settings correspond in any way to positions indicated on "Position" screen.
Thank you.
1320 stored stroke limit + value
1321 stored stroke limit - value
Sets the coordinate values of stored stroke limits 1 in the positive and
negative directions for each axis in the machine coordinate system.
you will be able to see those numbers on your position page when you are
looking at the machine coordinates (i.e. not absolute or relative readings)
when the turret is at maximum and minimum strokes
