Results 1 to 10 of 10
Thread: Fanuc Programming Problem
    Nov 2008
    Hoping this is the correct place to post this.
    Having some problems programming/running g-code on a Fanuc controller.
    Fanuc Series Oi Mate-TC
    Schaublin Lathe. Some of the g- and m-codes are a little bit different than what is typically used so I'll try to explain them.
    N1
    G90 G95 G18 G40 G80 (Typical Safety Line I've used in the past)
    T707
    G92 S2500 (Yes, its a G92 not the typical G50)
    G97 S1750 M103 (yes M103)
    G59 G00 X0.9 Z0.2
    /M08
    G73 U.010 R0.005 (I made the DOC really small to see what would happen)
    G73 P10 Q19 U-0.040 W0.003 F0.003 (Yes its a G73 instead of normal G71)
    N10 G00 G41 X0.95 (Cannot run Z movement or machine alarms here)
    X1.13
    G01 Z0.0 F.003
    X1.1 Z-0.015
    Z-1.0
    X0.95
    N19 G01 G40 X0.9
    G00 Z0.2
    M01
    Its a really basic canned cycle for boring out. But I cannot get it to work! The machine will only cut at X0.886" (smaller than even my first positioning at X0.9) and then at X1.06 (which would be on size for leaving what I want for finishing). Hence this is why I was running a DOC of 0.010, but this didn't even change how the machine would only take 2 roughing passes.
    I've been running Haas exclusively for about 4 years now. Before that Mazak. So this is the first Fanuc controller I've had to program, only button-pushed to help out when a man short before that.
    Thanks.
    Sep 2010
    Quote Originally Posted by URguys View Post
    N1
    T707
    G59 G00 X0.9 Z0.2
    /M08
    X1.13
    G01 Z0.0 F.003
    X1.1 Z-0.015
    Z-1.0
    X0.95
    N19 G01 G40 X0.9
    G00 Z0.2
    M01
    Thanks.
    The G92 and G73 is not surprising. There are three G Code Systems available, A, B, and C. Your control is using System C. The G Code System is selectable via parameter #3401, bits 6 and 7
    Bit 6 -- Bit7
    0 ------ 0 = A
    1 ------ 0 = B
    0 ------ 1 = C
    G Code System A uses G Codes that you're probably more familiar with and is the most prolifically used system.
    There are two versions of G71 (G73 in your case) Type I and Type II. Programming both X(U) and Z(W) in your N10 block is the way in which Type II is invoked and the fact that an alarm is raised indicates that your control does not have Type II available.
    Type I only permits X moves that are either increasing or decreasing in size in the profile description. In your program snippet, you start X0.95, peak at X1.1 and then finishes at X0.9 within the profile description; this is not permitted.
    Regards,
    Bill
    Registered fordav11's Avatar
    Aug 2011
    Fordaville
    you say you can not get it to work but do you get an alarm? what happens after the tool gets to X1.06? as a test try removing the G41 and see if it runs through.
    Nov 2008
    Quote Originally Posted by angelw View Post
    Regards,
    Bill
    Today I changed the X value to match the start X0.95... didn't work.
    I tried removing the X value on the G40 line... didn't work.
    I moved the X value larger than X0.95... didn't work.
    I removed the X0.95 and G40 X0.90 values all together so there wouldn't be any X movement... didn't work.
    I removed the G41... didn't work.
    And to fordav11
    The machine only errors out when I have a Z value in the G41 line, so I figured out the machine can only use Type I roughing. But it was nice to have you guys confirm that for me.
    After the machine takes its two roughing passes and finishes at X1.060 the machine does what it's supposed to do and move away from the part (I just didn't include the movement to safe tool change point in my original post).
    So I'm still at a loss.
    Sep 2010
    Its doing what its doing because, effectively, your trying to cut a profile that has non-monotonous X moves with G71 Type I. The action of Type I is that after the roughing cuts are completed, a single cleanup cut, the shape of the profile description, is made. As far as the control is concerned, the following attached picture is the shape of your profile. Its concave and not allowed with G71 Type I.
    In the following sequence of pictures:
    1. The first shows a part roughed using G71 Type II, initiated by including a Z(W) move in the P referenced block. The part was machined correctly.
    2. The second shows the same part being re-cut using G71 Type I, initiated with only an X(U) address included in the P referenced block. You will note that the tool has commenced to incorrectly machine the part on the first roughing pass.
    3. The third picture shows the same part shown in the first picture after the G71 Type I cycle had finished. The cycle kept taking roughing cuts through the larger diameter feature at the front until is reached the small diameter of the part. The cycle concluded by taking a final cleanup pass the correct shape as described in the profile description between the P and Q referenced block, but of course, the part was already destroyed.
    N10 G00 G41 X0.95 Lose this block
    X1.13 and make this block N10 G00 X1.13 and it should work
    G01 Z0.0 F.003
    X1.1 Z-0.015
    Z-1.0
    N19 G01 X0.9
    Accordingly, the code becomes:
    N10 G00 X1.13
    G01 Z0.0 F.003
    X1.1 Z-0.015
    Z-1.0
    N19 G01 X0.9
    As can be seen in the attached picture, the X moves in the profile description are moving in one direction, decreasing only, and therefore, is a legal profile for G71 Type I.
    There are quite a few versions of G71. Some do not support Tool Nose Radius Compensation (TNRC) at all. However, those that do require the compensation mode to be applied before the G71 block is executed, and canceled after the Q referenced block.
    You can come in out of the wilderness. Just make the changes as described above and the program should work. If your version of G71 Type I does not support TNRC, you will have to calculate the true location of the tool manually with consideration given to the Tool Nose Radius. This is not difficult, and with your particular profile, calculations for the start and finish of the taper between X1.13 Z0.0 and X1.1 Z-0.015 are the only calculations required for TNRC. Alternatively, if you have access to CAM system, create the tool path with the TNR being compensated by the Software and not the Control.
    Regards,
    Bill
    Nov 2008
    Sorry for late reply. Had to go onto something else and I just threw a G20 cycle in there to get it done.
    But I started playing again.
    The only way I could get the machine to cut an ID and to cut the correct DOC was to start below on X. Which does make sense in a way (in a way that I'm just not used to anyway).
    G00 G59 X0.65 Z5.0
    G41 X0.75
    G73 U0.010 R0.005
    N10 G00 X1.1
    G01 Z0.0
    N19 Z-1.0
    G40 X0.75
    G00 Z0.20
    So hooray, I got it to work. But if I can never start X+ when cutting internally and the machine is not capable of cutting Type II roughing, then am I never going to be able to cut a chamfer?
    Sep 2010
    This is a Fanuc control, therefore G20 isn't a cycle of any description, its the code for Imperial Input, G21 is for Metric.
    No, it doesn't mean that at all.
    1. To machine a profile in a bore, you need a hole to start with, that's a given.
    2. The start point in X for the cutting tool will be at a diameter <= to the diameter of the existing hole.
    3. The description of the profile to be machines is between and including the blocks referenced by the P and Q addresses of the G71 cycle. Accordingly, if there is a chamfer at the mouth of the bore from larger diameter to smaller, or an angled surface from one diameter to another further down the bore, so long as the tool continues to move from larger diameter to smaller diameter, then that's OK using G71 Type I. The attached picture shows whats legal and whats not with regard to the bore profile. The picture on the left is a legal profile using G71 Type I. The picture on the right is a legal profile only when using G71 Type II
    Regards,
    Bill
    Feb 2006
    india
    Does radius compensation work inside canned cycles. I have seen conflicting statements. Never experimented myself.
    Nov 2008
    Yeah, I thought about it after I went home and if it can't cut a chamfer then the machine wouldn't be able to cut anything but horizontal lines... and that wouldn't make sense.
    I'll play around with it again and see what this machine can do.
    Regards,
    Bill
    On this machine G20 runs a OD turning cycle. Equivilant to a G90 I think... never ran that before but it seems to fit the bill. Must be a Type C controller thing.
    Sep 2010
    Yes, I forgot that I'd mentioned that your control must be set to G code system C in a previous post. If you want to bring the control more inline with the more conventional system "A", the G Code System is selectable via parameter #3401, bits 6 and 7
    Bit 6 -- Bit7
    0 ------ 0 = A
    1 ------ 0 = B
    0 ------ 1 = C
    Regards,
    Bill
    1. problem with ug nx 4 programming
      By kumar_manikonda in forum General CAM Discussion
      Last Post: 01-14-2010, 09:19 AM
    2. Churchill programming problem
      By fisherb in forum G-Code Programing
      Last Post: 06-16-2008, 08:00 PM
    3. programming problem
      By NaRbO in forum Fadal
      Last Post: 05-04-2008, 03:06 PM
    4. PIC16F627A Programming Problem
      By Minesgeek in forum PIC Programing / Design
      Last Post: 10-30-2006, 10:21 PM
