Results 1 to 3 of 3
Thread: Data from Fanuc to Excel over Ethernet
    Mar 2007
    Hello, has anyone tried and been succesful at sending real time and logged data from a CNC lathe over ethernet so that the data can be viewed on any computer using Excel. My employer wants me to set up a network to all our machines so they can look at data from the office. Our Fuji lathes have a 180i-TB screen and in the cabinet has a cnc card A02B-0283-B801.
    Registered fordav11's Avatar
    Aug 2011
    Fordaville
    that 'card' is the entire CNC controller.
    A02B–0283–B801 - 18i/180i/180is Basic Unit (1 slot)
    That means nothing as far as it's capabilities are concerned. You may or may not have network connectivity. In any case it's extremely unlikely all of your machines have what you need to monitor data across the entire workshop using ethernet.
    it depends on what 'data' you want to view but IMO the amount of info needed (by someone clueless sitting in an office) would be quite low. cycle time/machine running in auto time/machine stopped or waiting time etc. just a few bytes per hour. a network connection is overkill for that amount of data.
    IMO monitoring does not usually solve production issues it only causes grief and fatigue between management and machinists. Dedicated CNC Machinists/CNC Programmers can solve almost all shop related production issues without any assistance. Management only need to simply move tongues and make speech-like noises while standing or sitting in front of said dedicated CNC Machinists/CNC Programmers (technically referred to as 'communication')
    Uh-hum. Anyway....
    You can output data to RS232 using macro with the DPRNT statement for zero dollars on any machine that has the macro option.
    Do a search here in the forums for 'DPRNT' if you want more info.
    The ethernet related stuff is probably not cheap to implement.
    From the Fast Ethernet board manual....
    The Fast Ethernet board can use the following functions:
    FACTOLINK function Series 16i/18i/21i-A/B
    DNC1/Ethernet function Series 16i/18i/21i-A/B
    FOCAS1/Ethernet function Series 16i/18i/21i-A/B, Series 15i-B
    The Fast data server can use the following functions:
    Data server function Series 16i/18i/21i-A/B, Series 15i-B
    The FACTOLINK function displays a work instruction on the CNC
    screen or transfers NC data, using the NC.
    The status of the machine can be automatically sent to a personal
    computer (Logging).
    The DNC1/Ethernet function enables the remote control and
    monitoring of the CNC from a personal computer.
    The FOCAS1/Ethernet function enables the remote control and
    The data server function uses FTP to transfer NC data or operate the
    DNC. This function is mainly used as an FTP client, but is also used as an
    FTP server. This function uses ATA flash card (ATA card) mounted on (connected
    to) the data server board as the storage area for the NC data.
    Registered CNC Data's Avatar
    Feb 2011
    United Kingdom
    Here's the alarm data.
    CNC Data Ltd
    www.cncdata.co.uk
  1. Excel / Kiwa 510 VMC Fanuc 0M) ATC Problem
    By MotoDan in forum Fanuc
    Last Post: 12-15-2012, 04:36 PM
  2. Need Help!- Excel Colt 510 with Fanuc OM problem
    By techscan in forum General Metal Working Machines
    Last Post: 09-14-2011, 08:41 AM
  3. Need Help!- Excel Colt 510 with Fanuc OM problem
    By techscan in forum Fanuc
    Last Post: 09-13-2011, 02:15 PM
  4. Need Help!- Ethernet Fanuc 18i-TB
    By ProToZyKo in forum Fanuc
    Last Post: 11-30-2010, 08:10 AM
  5. Excel 810 VMC Parameters Fanuc O-M
    By pvougi in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 09-05-2006, 01:57 PM
