These are pretty expensive. Is there any harm in using ordinary alkaline battery (say, duracell) in a suitable battery case, with the same connector soldered to it? Has anybody tried this? |
| As long as you can get the correct voltage, you're good to go. On older Fanuc controls, I replace the the pack of three 1.5v (4.5v total) with a 9v battery regulated to 5v. As it happens, the voltage should be 5v, but the 4v standard pack is within tolerance. I install this in a far more convenient to get at place, so its a big improvement all round. Regards, Bill |
If you're referring to my reference to the 4.5v and 5v, my application is different to that of Sinha's; I was merely pointing out that substitution is possible provided the voltage of the battery is correct. In my application, the original Fanuc battery was 3 x 1.5v cells connected in Series to provide a sum of the of the voltage of all the cells (4.5v). The actual wiring schematics specified 5v. Accordingly, I made up a small board that contained a 9v battery and a 5v regulator and connected it via the existing wiring. Battery replacement is now via an easily obtained battery. Regards, Bill |
| Done it MANY times over the years. I use the D cell holder that mounts in the door from Fanuc ~$50 us. Cut the pigtails off the lithium battery, solder it on a new cable and attach to the D cell box. Looks factory, you can change the batteries without opening the door, and about 6 bucks a year from then on. |
| Need Help!- Battery Replacement on Fanuc 0iMB | syamin | Controller & Computer Solutions | 4 | 10-12-2009 12:10 PM |
| Fanuc amplifier 6v battery / Mach3 | fomaz | Fanuc | 14 | 09-29-2009 10:59 PM |
| Strang Fanuc battery question | timlkallam | Fanuc | 2 | 12-05-2007 05:52 PM |
| Strange Fanuc battery problem | timlkallam | Fanuc | 0 | 11-22-2007 09:58 PM |
| Fanuc O-TC Battery Alarm will not reset? | valco | Fanuc | 2 | 07-17-2007 10:19 AM |
