HI All i have a problem with set zero in relative screen (lathe machine) when i want to set the tool in X or Z to zero in relative the value dosen't change to zero (only in relative coordinates) the machine is Colchester-Harrison GE Fanuc ALPHA X Series Lathe(touch screen) note : i have set up refrence return to the machine after the battery became low and released APC alarm X & Z need zero return , i changed the batteries and the machine works fine now except the relative zero for X& Z AXIS are there some parameter to change or something else? any suggestions, opinions or help will be appreciated thanks in advance |
| thnx for ur reply fordav 11 , actually that's my problem , i need to set zero in relative page, when i work with handle and touch the tool tip at the face of work piece and select relative page to set Z axis to zero it doesn't change the value to zero neither in Z nor in X axis the machine is: Colchester-Harrison GE Fanuc ALPHA X Series Lathe (touch screen) the controller is 21i |
1. Press POS Hard button 2. Select REL 3. Input Axis Name you want to Zero 4. Press ORIGIN Soft Key 5. Press EXEC Soft Key Regards, Bill |
| Fanuc Oi-MB Relative display | zooloader | Fanuc | 6 | 05-07-2008 07:57 AM |
| Relative coordinate display | SIG | Fanuc | 5 | 02-08-2008 11:27 AM |
| Absolute and relative | jorgehrr | CNC Machining Centers | 4 | 10-10-2007 03:42 PM |
| Fanuc 0M.. how do you zero relative? | OC_ | Fanuc | 5 | 02-23-2007 10:45 PM |
| relative position | Rocksalt | Fanuc | 2 | 10-24-2006 02:17 PM |
