Old 02-02-2012, 10:04 PM
tcom-frazzled is on a distinguished road
Fanuc 21i-MA hangs on linear interp (G01)
Folks,
I'm sure this is something simple the tI'm overlooking, but I'm having an issue figuring out why interpolation G codes on my machine are halting. Something must be overriding the federate, but I'm at a loss for what. Machine lock is off, FRO is set at 100%, feed stop isn't active. G00 motion work just fine, but G01 halts. looking at the active modal G commands that could affect this:
Machine is referenced, no alarms or estops
G17 is active (XY Plane selected)
G90 is active (absolute coordinates)
G94/G98 are active (feed per minute selected)
Assuming I'm at 0,0,0 in the current workpiece offset (G54)
The following command begins execution and you can see the cycle time counting up, but there is no corresponding motion on the machine.
G01 X10.000 Y10.000 F40;
Any ideas what other "stuff" could cause the interpolation federate to be overridden? I'm assuming this is what is happening, but I can't quite figure out what is holding the federate at zero. I even started up the spindle to see if somehow the federate was being used as a feed per revolution, no dice...
Thanks for any insight.
Old 02-02-2012, 10:13 PM
underthetire is on a distinguished road
You forgot the decimal point after 40..
Old 02-02-2012, 10:27 PM
New to Fanuc, so forgive me for the beginner stuff. I know that for coordinates, failing to put in a decimal point tells the machine that the measurement is in base units (0.0001 if I recall). I take it this isn't the case for feedrates, because the machine didn't even move a tenth after sitting for a few minutes while I was scratching my head.
I thought I had tried it with a decimal as well, but haven't been in front of the machine since this morning. I'll try it again with a decimal point and hopefully it is something that stupid.
Old 02-02-2012, 10:54 PM
Post back if not.
Old 02-03-2012, 06:20 AM
sinha_nsit is on a distinguished road
Post complete program.
Old 02-03-2012, 08:09 AM
I've just been doing some initial testing on the machine (it was a used CNC from a surplus dealer, so I'm going over it with a fine-toothed comb). I'm issuing single blocks from the MDI to check out the mechanical side of things. I haven't gotten to the point of loading up a test program to run yet.
Old 02-03-2012, 03:54 PM
Still no dice. Adding a decimal didn't seem to help. G00 works fine, but anything with a specified feedrate hangs.
Old 02-03-2012, 04:20 PM
sure your feedrate overide knob is not set to 0?
Old 02-03-2012, 04:23 PM
beege's Avatar
beege is on a distinguished road
on some machines, MDI commandas are ALL incremental. So if you type in X0 Y0, the table won't move.
Old 02-03-2012, 04:34 PM
I've never seen that, but G0 wouldn't work either then.
  #11   Ban this user!
Old 02-03-2012, 04:55 PM
That isn't it, I can put in any coordinates and still no motion. A little more digging shows this. Not sure what the cause would be. Stop motion or dwell shoes a value of 1. FRO is at 100%
  #12   Ban this user!
Old 02-03-2012, 05:14 PM
I guess the next step is to backtrack the signals in the ladder to see what the heck is going on. This is a Router that I picked up as surplus. The ladder could include some customizations that make the machine behave unexpectedly based on it being coded for a specific purpose.
madCAM hangs. Odd Egeland MadCAM 7 03-19-2010 07:00 AM
Site hangs when posting ger21 Forum Questions or Problems 11 12-10-2008 09:32 AM
Site hangs when posting? ger21 Forum Questions or Problems 49 11-27-2006 09:44 AM
Program Hangs! WOODKNACK TurboCNC 9 07-18-2003 11:19 AM
