Kitamura MyCenter 2 Fanuc 6MB control Machine was running fine until waiting at M0 command...then display went blank, tool carousel dropped down and just about every LED on the control panel lit up...except the alarm # output. Cycle the main power and control powers up but no display on control (CRT is energized but no display) and main relay never energizes. No LEDS lit on motherboard Green PIL LED is lit on Input Unit Green LED is lit on the board that has cables CO1 thru CO5 attached. I have verified that the Power Unit is outputting +5VC and +24VDC. Fuses that I could see all checked OK. Kitamura service indicated that is most likely a dead motherboard. Any other ideas?? THANKS. |
| Thanks, Bob |
| I could be a bad pcb like the CRT/puncher or the memory pcb (Bubble memory). CRT/Puncher pcb is th easiest to swap if you have another machine. Something else to check: There is a switch in the door. If this switch is open the machine will not power on, just a guess! |
| Update: CNC tech has determined that masterboard was indeed faulty since the clock signal was erratic. Replacement board was sourced and will be here next week. First question...Just double checking what the tech told me...Is the masterboard a straight forward interchange after making SURE all jumpers match? I have a battery backed up BMU card that should retain all parameters. Next question...After reviewing the the machine's work order history, I see that Fanuc service installed 2 chips to the old master board to enable additional work offsets. I'm assuming I will need to swap these chips if they are not present on the new board? Oddly, I have only had 6 fixture offsets available so I suspect the parameter was never enabled. Last question, I paid a little extra to get a masterboard that matched my rev level exactly....in case this board is DOA... any issues with swapping with a board of an earlier rev level? Thnks |
#10
| Thanks for the G54-G59 info. I have a separate ROM board that contains EPROMs. I see none on the masterboard. Also, the only other chips that are socketted on the main board are the axis LSI chips which my tech guy said should not need swapped. I will confirm everthing with him, just trying to educate myself a little. Thanks |
| 10TF boot fails | ncm | Fanuc | 3 | 04-12-2012 03:24 PM |
| Problem- TncRemoNt & TNC 426PB Transfer fails | tomdemets | Machine Problems, Solutions , Wireless DNC, serial port | 2 | 01-31-2011 02:20 PM |
| BMC-20 with Max32 upgrade - console fails at power-up. | DaveD | HURCO | 16 | 10-06-2010 06:39 AM |
| File upload fails | Snowie | Forum Questions or Problems | 0 | 08-06-2009 03:19 AM |
| Metric converter by Raiven fails | p38nut | G-Code Programing | 0 | 01-02-2006 08:44 AM |
