02-02-2012, 07:51 AM
Originally Posted by a_ravi_tn Hai, i am working in NTC - HMC with fanuc control, my problem is the feed and spindle override switch works more than 100% also. i dont want these feature. even if put 200% it must work max 100% only. so iwant to know what is the parameter or bit to activate? help me please. |
Originally Posted by fordav11 if you are concerned about operators changing the switches turn the key to disable the panel then remove the key. |
Sorry... what key; what panel? I've seen dozens (probably hundreds) of Fanuc controlled machines over the years, and I can't recall ever seeing a key which disables the panel. Maybe I've missed something.
In any case, as far as I can tell, he doesn't want to prevent the operators from changing the switches, he wants to limit overrides to a maximum of 100%. |
