Old 01-27-2012, 03:37 PM
vincerace's Avatar
vincerace is on a distinguished road
Toolchange macro to make multiple parts
There is someone interested by a toolchange macro i created that loop each tool for mutiple parts. IE you set one variable at the program start for the part quantity for example #800=4 and the machine take the tool 1 and make all the operations on G54,G55,G56,G57 and also if you want G54 P1, G54 P2, etc. and then take the tool 2 and do all operations in reverse G57,G56,G55,G54...really usefull when you want to choose part QTY right on the floor.It also support the G5 P10000 (ai Nano HPCC) function that doesn't support macro calculation when activated. If interested reply and i will post all is needed to do it!
Old 01-27-2012, 08:38 PM
fordav11's Avatar
fordav11 is on a distinguished road
there is always interest in macros that do useful things. please post it here if you want to.
Old 01-28-2012, 02:03 PM
John_B is on a distinguished road
I'd like to check it out as well!
Old 04-02-2012, 07:45 AM
vincerace's Avatar
toolchange macro
I finally posted it
there's the macro
O9000(TOOLCHANGE*MACRO)
IF[#4113EQ98]THEN#10=1
IF[#4EQ1]GOTO13(GO*BACK*TO*CURRENT*TC)
IF[#5NE#0]GOTO6(WPC*UP)
IF[#6NE#0]GOTO9(WPC*DOWN)
IF[#10EQ1]GOTO14(SEND*TO*END*OF*PROGRAM)
#3=#4114(SEQUENCE*N*FLAG)
#11=#149/100
#11=FIX[#11](CALC*TOOL)
#12=[#149-[#11*100]](CALC*PRELOAD)
IF[#11EQ0]THEN#11=#12(MANUAL*TC)
IF[#11EQ#12]THEN#12=#0
IF[#11EQ30]THEN#11=0(PROBE=T30*FOR*PRELOAD)
IF[#11EQ#702]GOTO5(SAME*TOOL*SKIP)
IF[#703EQ0]GOTO2(SKIP*ROTARY*PROTECT*IF*DISABLED)
IF[#1EQ#0]GOTO1(MANUAL*TC*PROTECTION*WITH*ROTARY)
IF[#7741EQ0]GOTO15(ALARM*IF*FACEPLATE*PROBING*NOT*DONE)
IF[#5021+[#1-#5041]GT#7741]GOTO2(SKIP*IF*TC*IS*SAFE)
IF[#5021+[#1-#5041]LE#7741]THEN#1=#5041-[#5021-#7741](ROTARY*TC*PROTECTION)
G5P0
M9
G91G28Z0M19
G90X#1
GOTO2
N1
IF[#5021LE#7741]THEN#1=#5041-[#5021-#7741]
G5P0
M9
G91G28Z0M19
G90X#1
N2
IF[#3GE2]GOTO3
IF[#4014NE54.1]THEN#801=#4014(SET*FIRST*WPC*G54-G59)
IF[#4014EQ54.1]THEN#801=#4130(SET*FIRST*WPC*G54*P1-P48)
N3
IF[#5021+[#1-#5041]LE0]THEN#1=#0(X-*OT*CHECK)
IF[#5021+[#1-#5041]GE60.7]THEN#1=#0(X+*OT*CHECK)
IF[#5022+[#2-#5042]LE-30.]THEN#2=#0(Y-*OT*CHECK)
IF[#5022+[#2-#5042]GE0]THEN#2=#0(Y+*OT*CHECK)
#700=#4001(MOVE*TYPE*FLAG)
#701=#4003(ABS*INC*FLAG)
M46
IF[#4120NE0]THENGOTO4(PROBE*SPINDLE*LOCK)
S0M47
N4
G5P0
M9
G91G28Z0T#11M19
G90X#1Y#2M6
#702=#4120
T#12
#1=#0
#2=#0
N5
G#700
G#701N#3
#1=#0
#2=#0
M1(OPTIONAL*STOP)
(SET*WPC*MULTIPART*SECTION)
IF[#800LE1]GOTO12(SKIP*SECTION*IF*ONE*PART)
#7=#3/2(CHECK*IF*TC*NWORD*IS*ODD*OR*EVEN)
#8=FIX[#7]
#9=FUP[#7]
IF[#8EQ#9]GOTO9(SEND*TO*WPC*DOWN*IF*ODD)
N6(WPC*UP)
#4=1
IF[#5NE#0]THEN#5=#5+1
IF[#5EQ#0]THEN#5=#801
IF[#5LE48]GOTO7
G#5
GOTO8
N7
G54P#5
N8
IF[#5EQ[[#800-1]+#801]]THEN#5=#0
IF[#5EQ#0]THEN#4=#0
GOTO12
N9(WPC*DOWN)
#4=1
IF[#6NE#0]THEN#6=#6-1
IF[#6EQ#0]THEN#6=[[#800+#801]-1]
IF[#6LE48]GOTO10
G#6
GOTO11
N10
G54P#6
N11
IF[#6EQ#801]THEN#6=#0
IF[#6EQ#0]THEN#4=#0
N12(RETURN*TO*PROGRAM)
M99
N13(GO*CURRENT*TC)
IF[#800LE1]GOTO14
M56
#4=#0
M99P#3
N14(SEND*TO*END*OF*PROGRAM)
#3=#3+1
#10=#0
#800=#0
#801=#0
M99P#3
N15
#3000=1(PROBE*ROTARY*FACEPLATE)
M99
(#1=TC*X*RAPID)
(#2=TC*Y*RAPID)
(#3=CURRENT*TOOL*NWORD)
(#4=RETURN*TO*CURRENT*TC*FLAG)
(#5=CURRENT*UP*WPC)
(#6=CURRENT*DOWN*WPC)
(#7=CURRENT*TOOL*SPLIT*TO*ROUND)
(#8=ROUND*DOWN)
(#9=ROUND*UP)
(#10=END*OF*PROGRAM*FLAG)
(#11=TWORD)
(#12=CURRENT*PRELOAD)
(#700=MOVE*TYPE*FLAG)
(#701=ABS/INC*FLAG)
(#702=CURRENT*TOOL)
(#800=PART*QTY)
(#801=FIRST*WPC)
there's a sample program
O6001 (18-19)
#800=1 (PART QUANTITY)
G17 G20 G40 G54 G90 G98
#1=-2.875
#2=-1.25
N1 T0610 (ENDMILL 3/8" CARBIDE 2FL.)
M3 S10000
G5 P10000
G0 X-2.875 Y-1.25 M8
G43 H6 Z-.175
G1 Y.25 F75.
G0 Z.5
X2.875
Z-.175
G1 Y-1.25
G0 Z.5
X2.2813 Y-.5
Z.1
G1 Z-.275 F40.
X2.2822
G3 I-.001
G1 X2.2813
G0 Z.5
X-2.2813
Z.1
G1 Z-.275
X-2.2803
G3 I-.001
G1 X-2.2813
G0 Z.5
G5 P0
#1=0
#2=-.625
N2 T1000 (DRILL 5/32")
M3 S4890
G0 X0 Y-.625 M8
G43 H10 Z.5
G81 X0 Y-.625 R.1 Z-.2719 F29.3
G80
M98 P9000
N3 M9
G53 X30. Y0 Z0 M19
M30
How do I make multiple passes on arc. Andrew96 Vectric 4 07-01-2011 11:16 PM
Toolchange macro/sub for OSP5000L nlh Okuma 7 10-02-2010 05:31 AM
Need Help!- how to get multiple parts from a bar firekoe Fanuc 13 02-11-2010 08:23 AM
KIWA excel 510 toolchange macro help bensoli General Metal Working Machines 0 12-29-2009 11:49 AM
Macro b multiple choice menu? tomi6678 Parametric Programing 2 12-12-2009 02:16 PM
