Old 01-26-2012, 07:27 AM
Drew's Avatar
Drew is on a distinguished road
Exclamation Spindle fluctuation issue
Originally Posted by Drew View Post
Burgmaster Mill 6M Spindle issue
6044-H007 model 3 AC spindle
Sometimes the spindle acts up speeds up,slows down and even reverses for just an instance.
Checked feedback and found sqr wave off a little on duty cycle. 35 to 40%
Sine wave feed back looks good (.6v wave at 2.5 rms)
I have pictures and video will add when i can.
I have two servo units and have seen it on both and was wondering if it could be the motor?
If I had something important to say it would be here.
Old 04-18-2012, 03:37 PM
Drew's Avatar
Could this be caused by line voltage being 246 rms?
Old 04-18-2012, 04:01 PM
Perfect Circle's Avatar
Perfect Circle is on a distinguished road
Have you checked your spindle encoder & spindle drive control?
Old 04-20-2012, 12:15 PM
dlservice is on a distinguished road
After watching that video it sure looks like a feedback issue with the encoder or cable. Have you checked all the connections on the cable ? That type of problem is not likely in the motor.
You could test the motor out of the system by applying 3 phase voltage directly to the motor and see if it runs smooth without issues. But still looks like feednack issue. Try another cable & or encoder.
Old 04-20-2012, 01:56 PM
underthetire is on a distinguished road
I've seen that once before, helping a friend. It was on a mori lathe with a 6 as well. It ended up being a built in sensor inside the spindle motor. It was a fanuc drive witha fuji motor. Cleaned, adjusted and it ran good. Ordered another sensor just in case.
Tags
6044 spindle
XV1000 Spindle Issue ggundrum Bridgeport and Hardinge Mills 0 11-16-2011 10:52 AM
Need Help!- Bridgeport/Romi Speed fluctuation Riverside192 Bridgeport and Hardinge Mills 2 12-01-2008 11:18 PM
X3 Spindle Issue? chns Benchtop Machines 6 11-26-2008 05:58 PM
Need Help!- Bridgeport/Romi Speed fluctuation Riverside192 Machine Problems, Solutions , Wireless DNC, serial port 0 10-13-2008 12:38 PM
Super X3 Spindle Issue dafowfidy Syil Products 7 01-09-2008 01:17 PM
