| There is a problem with the memory in your controller, it is unlikely to be simply a loose terminal, it is more likely that the controller has been affected by static electricity. The RAM chips need to be replaced, if you are lucky the rest of the controller will be OK. edit: it could be just one RAM chip.. but rarely worth only replacing one.
__________________ Sliding down the razor blade of life. |
| Sorry can't help you with getting parameters list.
| Unless you work for Fanuc and have access to technical info and original factory parameter backups the serial number is not required to fix it. The solution is of course to power on while holding certain keys so the SRAM memory is cleared then re-load the parameter backup. Although this task is usually not easily achieved by a novice. The OP first needs to ascertain if he can still punch out the parameters while the alarm is there. that includes the PMC parameters too! |
#10
| I am merely asking for machine serial number to see if I have data backup for a machine close to that. Oh, and if i am a Fanuc employee or a "Fanuc police", screen name "fanuservicetech" is an obvious choice... |
#11
| Machine Type: Mori seiki ZL 45 Serial Number: 102 NC Type: MF-D4 Code No: 93010434 |
| Problem- Did Mori Seiki Buy Hitachi Seiki? | Billet Sean | Mori lathes | 6 | 05-04-2011 10:12 PM |
| MORI SEIKI JR | CNC2NUT | Mori Mills | 7 | 05-02-2011 06:39 PM |
| mori-seiki | ron2008 | Mori Mills | 2 | 10-08-2008 03:22 PM |
| Need Help!- Mori Seiki SL3 | sudhirudar | Machine Problems, Solutions , Wireless DNC, serial port | 1 | 05-21-2008 01:29 AM |
| Mori Seiki SL-204 | dcworld | General Metal Working Machines | 1 | 07-27-2007 10:25 PM |
