is the servo on the z-axis same as the servos for the x and y?
if it is the same try swat the servo of the z axis with servo from x or y axis.
if the same servo alarms then you definitely have a problem with the servo if the alarm stays on the z axis then check the cables and the motor.
LinkBack URL
About LinkBacks
