Hello All; We have johnford sv-41 vertical machine with fanuc 18-imb series, our machine is stop sometimes while its running without any alarms, after this we reset and start again, we never meet like this problem before because we dont have any alarms, how can we do for this? if anyone has any idea to help me out,,, Thanks & Regards |
| I've seen that freeze up sort of problem on other machines. When some part of a CNC cycle begins, like as in a tool change, many things occur in sequence. Many of the sequences are event driven. Move to somewhere, and then wait (indefinitely) until a limit switch changes. If the switch is intermittent and doesn't close, either due to mechanical problems, or electrical contacts not working well due to too not enough current flowing to keep contacts clean then the sequence gets hung up. Also unplug and replug anything, cards, connectors, check for loose crimps by tugging wires. Problems can also occur if the line supply voltage momentarily drops (a brown out) during a critical part of a sequence, and the sequence no longer completes. As dcoupar, asks, is it always the same place?
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. |
| It does stop any where , its not same place and not same block, everytime is different so we do not think so about program and everytime our program is change but everytime problem is occur without any alarms, Our machine's electric cabinet is very dirty and we will clean and try to plug and replug all of cable then let you know, Thanks for help if someone has any idea about this, ı will waiting for your reply, Thanks & Regards |
| Do you have the manuals? check the diagnostic parameters for 'Display of Internal Condition of NC' , not sure what they are in the 18i in the 10/11/12 the start at 1000. These give the present status of the machine, especially valuable when no alarm shown. Al.
| Job Opening NEED MANY CNC EXPERTS!! | BILL WRIGHT CCR | Employment Opportunity | 0 | 06-24-2011 09:22 AM |
| Need Help!- Any YAG experts around? | dar303 | Laser Engraving & Cutting Machines | 6 | 08-31-2008 01:27 PM |
| Need Help from the experts | studysession | DIY-CNC Router Table Machines | 1 | 01-08-2008 08:00 PM |
| Any AB PLC experts? | jderou | General Electronics Discussion | 5 | 11-11-2005 07:14 PM |
| Question for you servo experts | kevincnc | DIY-CNC Router Table Machines | 2 | 03-12-2004 02:07 PM |
