Old 01-11-2012, 01:49 AM
movick_25 is on a distinguished road
Smile Fanuc ac spindle drive alarm#4
I have fanuc spindle board with Printed board A20B - 0009 - 053. the problems every give command M05 (spindle stop) some times alarm 4 Led ON (this mean Fuse F1,F2,F3 For AC input Blow Out), I checked fuse input but no fuse blow. if i press button reset at bottom left of board, alarm was reset. how can i solved this problem???
Old 01-11-2012, 11:22 AM
GPena is on a distinguished road
I suggest that you clean the fuse bases, usually they got dirty and give this alarm. If after that the alarm is there, then you have a problem in the board in the detection circuit.
Good luck.
GP,
Old 01-16-2012, 03:17 AM
thanks GP I will clean the base of fuse, and i will try it run. but which one of detection circuit of this drive? do you have the schematic diagram??
Regards
Movick_25
Old 01-16-2012, 09:45 AM
Sorry, I don't have diagrams.
GP.
Tags
1992 VF2 Alarm 123 spindle Spindle Drive Fault dafowfidy Haas Mills 15 05-14-2012 01:32 PM
fanuc spindle drive alarm no-10 r_mahesh77 Machine Problems, Solutions , Wireless DNC, serial port 1 09-12-2007 10:22 AM
Fanuc ac spindle drive alarm 01 suresh patil Machine Problems, Solutions , Wireless DNC, serial port 2 08-08-2007 02:37 AM
alarm 408 on fanuc 0-TD,AL34 on spindle drive sting Fanuc 2 07-19-2007 01:17 PM
Spindle drive alarm in fanuc 16 ta miguisu Fanuc 3 02-20-2007 10:12 AM
