Ihave to upload parameters: IPL screen passed then machine on with MDI mode but i can not change mode (such as Jog, edit, rapid..). screen shows some alarm as below sv026 X illegal axis arrange sv027 x ill dgtl servo parameter sv027 x ill dgtl servo parameter ot100 spindle alarm as well machine error lamp in on. i tried to give some parameter in MDI Mode manually. but i could not found those paramenter number which i need such as (1023,.....etc...) IPL screen May i know while after input 99 machine ask axis? what number i need to give? just 2 only enough.. or anything else.. waiting for your kind reply. |
| for a lathe axis = 2 ignore the alarms. you wont be able to exit MDI until all parameters are input (incl. PMC parameters). or at least enough to make the machine work. for now input all common parameters then power machine off/on and see what happens. |
| how can i input parameters in MDI mode. because there is no softkey function punch which is only edit mode. if MDI mode okay, please tell me the procedures how can PMC parameter input the machine why some parameter numbers there is no in our machine. thanks for your replay. again i am waiting for you |
| follow the restore procedure here. http://www.kfasllc.com/memory_backup_restore_F1011.htm |
| Yes i followed up now okay i can restore parameter through rs232 cable. when read parameter machine, suddenly show this message parameter looked, what is the reason? help me please
| Need Help!- Fanuc Oi-TC Control Memory Card Error | Brenda Cash | Fanuc | 9 | 06-29-2011 04:03 PM |
| FANUC 18iT, muting the lamp | MRPM | Fanuc | 1 | 04-07-2011 03:52 PM |
| Fanuc Pro 3 Control 16i Memory Card Error | bassboarder85 | Fanuc | 12 | 11-12-2010 03:24 PM |
| Problem- 1982 fanuc 6m control (Enshu) 401 servo error | Rob Lacy | Fanuc | 7 | 10-26-2008 02:51 PM |
| Fanuc 15-M... Spindle Off lamp stays ON | cncnovice | Haas Mills | 11 | 05-11-2006 09:04 AM |
