01-03-2012, 08:53 AM
below procedure i followed then what i need to do? | | 1. Make sure you have a copy of your parameters, pitch error compensation parameters, part programs, and tool offsets. These can be punched out to your pc. You will have to write down the 9000 parameter and 9100 through 9139 parameters, also you will have to write down your PC parameters: Data table, Timers, Counters, Keeprl and Pos. these may have more than one page so make sure you page down. If you don’t want to write, I take a photo of each page with a digital camera, check you can read them.
2. Power off the machine and power up holding in the “7” and “9” pushbuttons this should bring the machine up in the IPL screen.
3. Press the “9” button twice, and then press “Input” This will enable system label generation.
4. Press “Y” pushbutton to generate system label.
5. Next you will be ask “NUMBER OF AXIS?” enter the value that was in parameter 9000 then press “INPUT”.
6. You will then have to enter “OPTIONS 1 through 40”(parameters 9100 through 9139) these parameters have to be loaded in Hexadecimal Notation. If a option parameter is all zeros just press “INPUT” otherwise enter the two digit Hex number and press “INPUT”
7. Once you have loaded all the OPTIONS the screen will ask you to erase certain files, press “Y”
8. This will bring you back to the IPL screen. To exit this page press “6” and “INPUT”
upto this step okay, then same screen show? how can i go normal operation screen? I dont have any maintenance manual? please help me anybody |
