Old 12-29-2011, 09:28 PM
John_B is on a distinguished road
Toolsetting macro on 0m-C
Can anyone help me understand why my old machine (1990) with the 0m-C control is balking at the T code shown below?
:9010(SINGLE TOOLSETTING)
G00G30G91Z0
IF[#20EQ#0]GOTO3000
T#20 <<< THROWS ALARM 043 HERE<<<
M6
Or also in the one:
:9011(MULTI TOOLSETTING)
G00G30G91Z0
WHILE[#19LE#9]DO1
T#19<<< THROWS ALARM 043 HERE<<<
M6
IF[#19EQ#9]GOTO5
T[#19+1.](PRE-CALL NEXT TOOL UP IN T/C)
N5 ...
I am trying to use the Renishaw tool probing macros on this old dog, but it's not going well. I've found the alarm description in the manual, but can't find anything else to steer me straight.
Thanks,
John B
Old 12-29-2011, 09:32 PM
fordav11's Avatar
fordav11 is on a distinguished road
043 is illegal T-code command
check your macro variables page. what are #19 and #20 set to?
it needs to be set to a non-null, non-negative number within the range of your tool rack
Old 12-30-2011, 02:06 AM
dcoupar's Avatar
G00G30G91Z0
IF[#20EQ#0]GOTO3000
M6
Or also in the one:
G00G30G91Z0
WHILE[#19LE#9]DO1
M6
IF[#19EQ#9]GOTO5
N5 ...
Thanks,
John B
How are you calling the tool setting macro?
G65 P9010 T11
G65 P9011 S01 T06
or something like that?
Old 12-30-2011, 09:05 AM
I call 9011 like this:
G65P9011S4E4
The S pulls over the starting tool #, and E the ending tool #.
And I call 9010 like this:
G65P9010T16D1.5
The T pulls in the only tool to be set, and the D is the diameter.
These exact macros works great on my machine with an 18im-B control. I'm sure it's something that the older 0m-C doesn't like about using the variable reference with the T code. I suppose I could use #4120 and set it at #19, then just call the M6 to load the tool.
G00G30G91Z0
WHILE[#19LE#9]DO1
#4120=#19
M6
IF[#19EQ#9]GOTO5
N5
Do you think that'll work? I can't tell if the #4120 system variable is the tool in the spindle, or the tool called up next by T code for toolchange...?
I can't test it just now as I'm in the middle of running some hot parts that have to ship today. I will be able to monkey with it some more after about 5:00 p.m.
Thanks for the feedback!
Rgds,
John B
Old 12-30-2011, 10:45 AM
fordav11's Avatar
#4001 to #4120 are for reading modal information. the manual states they can be read but
does not specifically say they can be written. so #4120 = #19 won't work since its assumed
to be read only. #4120 is the T number of whatever tool was called last.... i.e. the T in
memory on your model page. try it anyway you never know it may work.
also try using a common variable that stays in memory. for example.....
#500=#19
T#500
also check this thread, post#29
http://www.cnczone.com/forums/fanuc/137761-fanuc_om_lost_tool_change.html
it uses Macro A but has a T#149 and it's an 0-series like yours.
#149 is a common variable but is cleared when the control is powered off.
from #500 upwards they are not cleared at power-off.
another possibility is maybe it needs T#19 M06 on the same line?
Old 12-31-2011, 03:49 PM
angelw is on a distinguished road
G65P9011S4E4
G65P9010T16D1.5
G00G30G91Z0
WHILE[#19LE#9]DO1
#4120=#19
M6
IF[#19EQ#9]GOTO5
N5
Rgds,
John B
John,
The system variable is not your problem. Typically the modal system variable for the Tool number is used so that the current spindle tool, if its the number being called, is not shifted out of the spindle, or to avoid an error being raised. However, this is somewhat dependent on the PMC program.
Its use would be something like the following, but would normally be in the Tool Change Macro if the machine uses one (also PMC program dependent)
IF[#4120EQ#19]GOTO100 (IF THE CALLED TOOL IS CURRENT, BYPASS TOOL CHANGE)
T#19
M6
N100
I would do as Ford suggested in an earlier post, and check the value of #19 and #20 after the Macro program has been called to see if thy're in the range of the Tool Magazine capacity. However, the use of arguments in your Macro Call to pass values to #19 and #20 should ensure that these variables are set, and therefore, the only way these variables may be out of legal range would be to pass incorrect values. Run the program in Single Block mode, though you will have to set a parameter (#0011.5) so that the program stops after each Macro Statements. If the values are legal, temporarily use a real number, one that is not the current spindle tool, instead of the variable, ie T1 instead of T#19, to see if you get the same error. If you still get the error, it may have something to do with how the Tool Change is executed as suggested by Ford.
Regards,
Bill
Old 01-02-2012, 02:03 PM
Got it, it was the T call and the M6 being on seperate lines for part of it (machine has an umbrella toolchanger).
Worse yet though was that the main setting macro was using the same variable # that the G65 macro was passing the tool number over with, and that was the REAL problem. It was causing all sorts of calculation problems. Once I listed all the variables being used and caught the conflict, all it required was renumbering.
Thanks for the help!
Rgds,
John B
Need Help!- Macro A or Macro B On fanuc o-md macrosat Fanuc 1 07-29-2009 06:49 AM
Testing program for Macro (Fanuc Macro B) NickDP Fanuc 2 03-27-2009 03:15 PM
new inexpensive automatic toolsetting device product henry_phd General Metal Working Machines 0 07-13-2008 11:34 PM
need help with toolsetting macro parksteel General CNC (Mill and Lathe) Control Software (NC) 3 06-06-2008 09:15 AM
Convert Fanuc Macro to Fadal Macro bfoster59 Fadal 1 11-08-2007 11:41 PM
