Old 12-29-2011, 02:59 AM
android16 is on a distinguished road
System Alarm no. 3 Program Memory : PARITY HIGH
Alarm message " Parity High " appeared after turning - on the machine . Machine control is FANUC SYSTEM 3T . All function keys are disabled .Help me guys!!!Thanks
Old 12-30-2011, 11:15 AM
tmbruno28 is on a distinguished road
only one way....Complete clear...
parameter enable switch on (upper right on main board)
press reset and delete at power on,
you now have to enter all data !
good luck
Old 12-30-2011, 11:53 AM
fordav11's Avatar
fordav11 is on a distinguished road
let's hope he did a backup of all parameters prior to this event otherwise we'll see him here again asking if anyone has a 3T parameter backup
Old 12-30-2011, 01:45 PM
I think so .... but it's too late for thinking !!!
Old 01-01-2012, 11:06 AM
Thank you TMBRUNO28 for your good advice,it was really appreciated but Reset + Delete at power -on also not work instead , i used " P + CAN + DELETE " at power-on . All parameters had been reload machine is OKAY now. Thank's guys !!!
Need Help!- ALARAM 22 MEMORY PARITY ERROR tonny2105 Mazak, Mitsubishi, Mazatrol 2 03-20-2012 01:48 PM
911 ram parity high on FANUC 0T mate gunawan_tehnik Fanuc 8 11-07-2011 07:02 PM
Need Help!- C-MOS PARITY ALARM, FANUC 3 M JGPerry General CNC (Mill and Lathe) Control Software (NC) 1 10-09-2008 06:47 AM
Need Help!- system alarm 904& bubble memory sting Fanuc 2 03-05-2008 04:17 PM
How to erase ALL T2 OP parameter and 22 NMI Memory Parity problem? Donatello Tam Mazak, Mitsubishi, Mazatrol 0 07-14-2007 12:01 PM
