Old 12-27-2011, 08:26 AM
bigtown is on a distinguished road
drip feed and index at same time.
(Daewoo DMV 4020D) and controller (Funuc 21I-mb) does not have enough memory to run from controller. I have to drip feed the program from the card.
My problem is to run from the card I have to change parameters. I also have to change parameters to run the index head. these run on the same parameter so I Have to choose which the index head or the card.
I have a program that requires both the index head and the memory card.
Is it possible to ues both at the same time on this machine???
Old 12-27-2011, 09:23 AM
fordav11's Avatar
fordav11 is on a distinguished road
the same parameters? which ones exactly?
do they work ok when run separately?
i.e.
can you run from the card with normal drip feed?
can you run the index head with normal drip feed?
Old 12-27-2011, 09:28 AM
Yes I can do both.
I need I/O channel 0 for 4th axis and I/O channel 4 for card.
Therefore, I can not run both at the same time.
Does this make sense???
I feel like it sould be possible to do both.
Old 12-27-2011, 09:32 AM
fordav11's Avatar
ah I see. The I/O channel is conflicting.
There's not a lot you can do there.
It should be possible to set your 4th axis to I/O channel 1 but you will need help with it since there are probably a lot of parameters that need to be changed.
Old 12-27-2011, 10:19 AM
It seems like this would be a common set-up, running an index head with while feeding off the card.
What would be the most common fix for this issue? More memeory on the control?
The control needs to read off the card the program is too large for the memory. the control also needs to read info for the index head.
Old 12-27-2011, 11:28 AM
dcoupar's Avatar
Assuming you don't need feedback from the Index head, change parameter 110 bit 0 to 1 and you can control the I/O devices separately. Parameter 20 controls the Input device, and Parameter 21 controls the Output Device. Thus, you can Output to the RS232 port and Input from the card.
Old 12-27-2011, 11:39 AM
This sounds very logical
I am going to attempt it and will return my results for future searches
Thank you,
Old 12-27-2011, 11:40 AM
dcoupar's Avatar
As a caveat, if you have to change this setup very often, you can use "Programmable Parameter Entry" to change parameters from the program, rather than through MDI.
The following will set both parameters 20 and 21 to 0 for I/O through the RS232 port.
G10L50
N20R0
N21R0
G11
The following will set parameter 20 to 4 and parameter 21 to 0 for input via the card, and output through the RS232 port.
G10L50
N20 R4
N21 R0
G11
Drip feed DNC forhire NCPlot G-Code editor / backplotter 0 07-09-2011 10:59 AM
RS232 Drip Feed time out? Maybe Rocko1 Haas Mills 1 03-03-2010 01:10 PM
Need Help!- Drip Feed kirby Fanuc 23 10-20-2008 09:21 AM
RS232 Drip Feed time out? Maybe Rocko1 Haas Mills 5 02-06-2008 03:15 PM
Drip Feed camtd Surfcam 0 07-31-2006 06:09 PM
