Old 12-23-2011, 03:08 PM
ess178 is on a distinguished road
Fanuc 16 i MB PCMCIA Card
Hello,
I am trying to use the PCMCIA port on this machine to load programs. Everytime I try and access the card the machine alarms out with "930 CPU Interrupt" and requires a restart to clear.
The same card setup works in a different machine, and I set the I/O Channel to "4" per the instructions. I also set the enable paramater, I beleive #138.
Any help would be greatly apreciated.
Old 12-23-2011, 03:51 PM
underthetire is on a distinguished road
Early I controls would not read ata flash cards. SRAM cards only. I had the same issue when they first came out working at the mori dealer.
Old 12-23-2011, 11:05 PM
fordav11's Avatar
fordav11 is on a distinguished road
some i controls won't read cards greater than 512M. I've used 64M and 128M cards on my 21i without any problems but a 2G card does not work.
parameter 138 only enables DNC operation from the card but there are other settings required for it to work. enabling 138 bit 7 alone is not enough. the DNC hardware options are also required but you don't need it anyway. setting the I/O device to 4 is enough to enable the card slot.
Fanuc 18i PCMCIA card question TDavid Fadal 9 02-11-2011 06:45 PM
Need Help!- DNC with pcmcia card Scottjit Fanuc 2 01-25-2011 02:03 PM
PCMCIA card on Fanuc 18M buildyourown Fanuc 5 12-04-2010 05:32 AM
Need Help!- 0i-TB and PCMCIA CARD CHANDRU Fanuc 3 11-03-2008 06:19 AM
PCMCIA Card bdwalker Fanuc 4 03-13-2006 03:36 AM
