Old 12-23-2011, 09:30 AM
rai rai is offline
rai is on a distinguished road
Smile fanuc 15TF ram parity error
I am getting Ram parity error (Base 0) in Fanuc 15TF cnc system.
How do i initialize Fanuc 15Tf?
What about it's password?
99?????
please help me somebody, as i am not familier with fanuc 15tf cnc system.
Old 12-23-2011, 07:40 PM
memoryman is on a distinguished road
Your BASE0 board may be defective.
If you have an electronic parameter backup , you don't need the password:
Turn the control ON while pressing “7” and “9” on the MDI keypad until you see “CLEAR FILE” come up on the screen.. This erases all information in the system.
Wait until the CLEAR is finished.
Exit IPL screen by pressing “6” and then “INPUT” on the MDI keypad.
You will see many alarm messages because none of your parameters have been entered. Ignore these alarms.
Press “LEFT ARROW” soft key twice.
Press “SETTING” soft key twice. This will give you the SETTINGS(SETTINGS) SCREEN.
Press “PAGE UP” on the MDI keypad. This will bring up the 8000 SETTING parameter on the screen.
Press “1” on the MDI keypad.
Press soft key “ON:1”. This turns ON all of the bits in the 8000 parameter.
Press “LEFT ARROW” soft key and then press “SERVICE” soft key.
Enter communication parameters.
Do the following steps twice, turning the control OFF and ON after the first time.
Press “RIGHT ARROW” soft key twice.
Press “READ” soft key.
Press “ALL” soft key.
The word “READ” will be flashing on your screen.
Set your personal computer to download the NC Parameter File to the control.
Press “ENTER” on your computer to begin downloading data.
You will see “LOCKED PARAMETER” on your screen. Ignore this.
When “READ” stops flashing on your screen, downloading is complete.
Turn control OFF, wait a few seconds, then turn control back ON.
REPEAT PREVIOUS STEPS.
Now you can restore all lost info: programs, PMC data, offsets etc.
Here is the password set in case the above does not work:
23678625 input
37264699 input
19261161 input
Now set PWE and enter parameters.
You can call me Tuesday the 27th: 289 389 6117
Old 12-23-2011, 10:25 PM
rai rai is offline
Smile Thanks
thank you very much for your prompt reply, i will try by today.
23678625 input
37264699 input
19261161 input
Old 12-27-2011, 10:06 AM
rai rai is offline
Smile
I went thru your procedure that you explained me, by pressing 7 & 9 keys until CLEAR FILE screen in IPL mode. I have cleared all data in system then exit IPL screen by 6 key then input. but again I am getting Ram Parity alarm (Base0) after exiting IPL screen.
How do I use these passwords, As I don't have this machine electronic backup. What I did wrong?
Please help me...................
Old 12-27-2011, 12:38 PM
You did nothing wrong. It appears that your BASE0 board is defective, and if so, you lost all volatile data. We may have a good BASE0 for sale but need the part number.
Untill the hardware problem is fixed, you cannot proceed.
Old 01-12-2012, 10:11 AM
rai rai is offline
Smile
Now Ram parity error got eliminated but I donot know that how do I proceed further as I donot it's parameter backup.
Presently I am looking for it's option parameters of Fanuc 15TF.
Even I could not able to turn PWE = 1, I am getting write protect error.
Kindly help me.
Old 01-12-2012, 02:48 PM
not having the nc and pmc parameters makes it an almost impossible task.
You will have to enter the options first using the correct password. Do you have a list of your options? Nothing at all?
Old 01-13-2012, 08:36 AM
rai rai is offline
Thanks , I do not have option parameter backup.
As my Takisawa TC-2 MK-II machine having 2 axis, spindle motor analogue & tool setting probe.
Kindly send me option parameters.
Old 01-13-2012, 08:16 PM
selecting options is dependent on the actual machine configuration. It can take many days of an expert on site to get the machine running again. Your best option is to find an identical machine/control and copy the parameters.
Old 01-13-2012, 11:03 PM
rai rai is offline
I am trying to find same machine in our region but no success yet.
If i can have option parameter list then It might be helpful to me.
Please somebody do send me the same.
ahe_303@rediffmail.com
  #11   Ban this user!
Old 01-13-2012, 11:09 PM
fordav11's Avatar
fordav11 is on a distinguished road
it won't help to have just the option parameters. even then some of them are not obvious if you have it or not. if you enable something you don't physically have it will cause more trouble.
the bottom line is you have no other parameters, no PMC parameters, nothing.
you need to get professional assistance from Fanuc.
  #12   Ban this user!
Old 01-13-2012, 11:45 PM
rai rai is offline
Smile
Thanks, Fanuc won't give any assistance in India for 15TF control. Machine parametrs & PMC parameters might not be an issue, we can try atleast.
As this machine is a simple turning machine (Takisawa TC-2 MK-II) equipped with 2 axis servo motors, analogue spindle drive Fuji & tool setting probe.
as upto 40 opt parametrs need to configure this machine.
Kindly help me.
Need Help!- fanuc 10T ram parity error jolulank Fanuc 14 01-04-2012 04:23 AM
Need Help!- FANUC PARITY ERROR DIE FAST Fanuc 14 06-15-2011 07:10 AM
Need Help!- Fanuc 10 M Ram parity error cncmori Fanuc 5 12-11-2009 10:44 AM
Need Help!- Fanuc 3M ROM PARITY ERROR gyrodog General CNC (Mill and Lathe) Control Software (NC) 0 12-12-2008 04:45 AM
Bus error mesage at Fanuc 15TF bobecm Machine Problems, Solutions , Wireless DNC, serial port 0 08-27-2007 02:47 AM
