Old 12-16-2011, 11:04 PM
M.RISHIKESH is on a distinguished road
Phoenix Gleason 500HC CNC Hypoid cutting Machine No. 899401 with GE Fanuc Series 150M
Dear All
Subject Machine is working fine.
Please find below details of Hard Disk in the subject machine:
HDD UNIT A08B-0047-C011 NO. N0398
MODEL M2611SA
P/N (Part No.) B03B - 7065 - B111A#LP
FUJITSU LIMITED MADE IN JAPAN
SER. NO. 575635 DATE 1994-10
RATING +12VDC 2.0A , + 5VDC 1.0A
There is white round sticker, marked at the bottom of it as Label G
This Hard disk has a 4 pin power connector and 50 pin data cable (25 X 2rows)
Please let us know on how to take clone (or complete image) of this hard disk
Best Regards,
M. Rishikesh
Old 12-16-2011, 11:31 PM
fordav11's Avatar
fordav11 is on a distinguished road
Its a common Fujitsu M2611SA 45MB SCSI-1 hard drive.
Cloning it is very simple using any PC with SCSI interface and hdd cloning software. Use any larger size SCSI-1 or SCSI-2 HDD. The cloning software will copy the same data and the remaining unused space will be ignored.
When chaining multiple SCSI devices in a PC the SCSI ID and SCSI termination must be set correctly.
You will need a PC with a SCSI card (Adaptec is the most common brand) and cloning software like Norton Ghost, Acronis True Image etc
Do it immediately the hdd is 17 years old!
Need Help!- CRT for Gleason(Phoenix) Gear Cutting Machine with GE Fanuc Series 150M M.RISHIKESH Fanuc 3 09-16-2011 05:04 AM
JD Series Laser Engraving Cutting Machine echojdlaser Laser Engraving & Cutting Machines 0 12-03-2010 08:40 AM
Need Help!- Gleason(Phoenix)Gear Cutting Machine Model 500HC with GE Fanuc Series 150M M.RISHIKESH Fanuc 0 10-25-2010 12:39 AM
Need Help!- Phoenix Gleason 500HC CNC Hypoid cutting Machine No. 899401 with GE Fanuc Series 150M M.RISHIKESH Fanuc 2 10-16-2009 07:22 AM
Need Help!- GE FANUC SERIES 150M M.RISHIKESH Fanuc 2 10-06-2009 07:56 AM
