| Hi all Not sure if this is the right place to post this or not.. but here go's I'm having troubles at setting up Type 2 G71 Canned cycles witch i need as there is pocketing in the Z axis The machines errors out 065 when it runs the first line of the roughing cycle HTML Code: % ' This program Machines the Z profile 'Material 2in out 65mm from chuck :0003 'Program number N010 G50 S1500; 'Set max chuck speed N020 G96 M04 S200; 'Turn on constant surface speed, Start splindle clockwise @ 200M/Min chuck speed N030 G99; 'Turn on feedrate mm\rev N040 /M08; 'Option turn on coolant N050 G00 X52.00 Z1.00; 'Rapid positioning, Move to position X52 if a bit bigger than the diameter of the stock work peice N060 G71 P070 Q190 U0.5 W0.00 D1000 F0.25; '(G71)Z Profile,(P060)Start of facing cycle,(Q070)End of facing cycle,(U0.5)Finishing allowance X directing.(W0.25)Finishing allowance Z directing,(D500)Depth of cut 0.5mm. N070 G00 X31.00 Z0 ; 'Start of tit on the end ---------Errors here------------- N074 G01 Z0.00; N075 X31.75 Z-0.5; 'Tit in the end N080 X37.00; 'Start of taper N090 X40.45 Z-5.70; 'Cut taper N100 Z-17.10; 'Thread leadin start N110 X45.00 Z-19.38; 'Thread lead in N120 Z-28.25; 'Thread length N130 X41.50 Z-30.00; 'Thread lead out taper N140 Z-33.40; 'Tharead Clearence N150 X49.30; 'Start of taper N160 X50.8 Z-34.10; 'Cut taper N170 Z-39.25; 'Head flange length N180 X49.3 Z-40.00; 'Cut taper N190 Z-45.00; 'Clearence cut 'finishing N200 G70 P070 Q190 F0.15; '(G70) Finishing cycle,(P060)Start of facing cycle,(Q070)End of facing cycle N210 /M09; 'Option turn off coolant N220 M99; ' Return from sub program % As expected the code runs if i leave out the Z0.00 but the pocket is missed out on the roughing cycle but is done on the G70 finishing Then manual says it can do it but there is no examples. I've had a Google and the examples i find have the same issue What am i missing Cheers |
| what is alarm 065? The manual states pocketing in the Z axis with G71 can't be done even if Type II is enabled. also read this thread.... http://www.cnczone.com/forums/fanuc/...-t_help-2.html it has a lot of info about type II roughing cycles. |
| Hi Sorry i might have lead you a-stray. The pockets are along the Z Axis (Shaft with groves and shapes along the length of it) Code 065 is a long windered one. But here is the tail end of it "in G71 & G72 , Z(W) has been commanded (G71) OR X (U) has been commanded (G72) in the block of Sequence No. Commanded by P" When you say
If so How do i check Page 158 & 159 of my manual goes on about type 1 and type 2 Cheers |
The result that you achieved by leaving out the Z move in the P referenced block is typical if you include a non-monotonous X move when using Type I G71, which is what you have when only an X(U) command is made in the P referenced block. Its also typical that the G70 cycle will follow the profile; it will always follow the finished profile exactly. In fact you can use G70 to run a profile between Sequence numbers referenced by the P and Q commands in the G70 block without having previously executed a G71 or G72 cycle. Regards, Bill |
| Tags |
| g71 type 2 |
| Problem- Fanuc 18i on Fadal Troubles? | fizzissist | Fadal | 2 | 02-16-2010 06:47 AM |
| Fanuc triple servo drive troubles | fasto | Fanuc | 2 | 02-12-2010 01:19 PM |
| Fanuc 11T Soft limit troubles on Slant-1 | shupej | Fanuc | 2 | 09-26-2007 04:30 PM |
| Fanuc 6T RS232 Troubles | Bent82 | Fanuc | 6 | 02-06-2007 12:57 PM |
| fanuc 0m-B troubles | sammer003 | Machine Problems, Solutions , Wireless DNC, serial port | 2 | 01-25-2007 05:32 AM |
